Home > Maintenance & Mods (L322) > Frustration of owning a Rangey
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
FF is out of warranty so think it’s now time to start maintaining it myself, fairly handy with spanner’s so no worries.
Get service parts ordered in, realise FFS I ordered a 9L oil drainer by mistake.
Think to myself send it back Rob, you need to tackle the noisy idlers anyway . Do them 1st while 10L one isn’t available.
Idler parts sourced & do that pig of a job. Finish up & all quiet, result. Test run & no issues👍
Commute to work BONG restricted performance, iiD looks like an air leak in intakes somewhere.
Have a fiddle with it & test drive BONG is back, ok need to smoke test it
Pull onto drive & loads of smoke appears, hmm this isn’t the smoke test I planned🤔 aarrghh sticking rear calliper.
Time to tackle the calliper 1st then, can’t road test without doing it.
Time to jack it up then & assess what I need. Pop pssssssssfffffttttttt & we all know what that is🤬
Thanks for listening, rant over.
Beer time!!!!
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #587804 17th Mar 2021 7:40pm
kevinp
Sorry to hear of your woes. I have a perfectly good rear left caliper for the cost of the postage if it helps you out.
Post #587826 17th Mar 2021 10:12pm
RJH
Hi Kevin,
Thanks for the offer.
Was it taken off yours & is still in working order? Ie not sticking.
Happy to pay the postage if it’s a working unit.
Much appreciated,
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #587832 17th Mar 2021 10:37pm
kevinp
Hi Rob. Yes it is off my 2011 car. The right hand one suddenly started to seize and the piston was in a right rusted state, so I replaced both calipers. I took the piston out the left one and it is virtually unmarked. The piston pushes in easily just with finger pressure and when I applied a bit of air pressure to it the piston withdraws a little when the air is let off as it's meant to. PM me mate if you want it.
Post #587841 18th Mar 2021 2:54am
GGDR
nice offer kevinp Thumbs Up Cheers, Greg
Post #587847 18th Mar 2021 8:17am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
for pullies and belts have a watch of this and the second one
&t=430s
wish i had seen this before getting mine done. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #587855 18th Mar 2021 9:24am
RJH
Cheers Jay,
I could have done with this a couple of weeks ago, looks like he was doing it at similar time to me looking at when he’s posted it. would have been really handy.
He’s made that look easy. Space is the issue you just cant get at stuff making it frustrating & there’s a bolt hidden behind the turbo actuator I’d do it pretty quickly the 2nd time around now I know it.
The viscose fan he struggled with was actually really easy for me once I’d made the tool. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #587965 18th Mar 2021 11:30pm
RJH
Very very generous Kevin,
You have a DM Thumbs Up
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #587966 18th Mar 2021 11:33pm
kevinp
Hi Rob. Sent you a PM but I don't think it's sent it.
Post #588041 19th Mar 2021 4:58pm
RJH
Got DM thanks Kev.
Just replied.
FYI Think it sits in your outbox until it’s read by the recipient.
Thanks again,
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #588045 19th Mar 2021 5:35pm
kevinp
Post #588056 19th Mar 2021 6:57pm
RJH
Many thanks Kev, calliper arrived today.
Really appreciate the support.
Donation made to the forum Thumbs Up
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #588490 22nd Mar 2021 11:05pm
kevinp
Your welcome. Thumbs Up
Post #588496 23rd Mar 2021 12:48am
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
you can get a pair of new rear calipers for about £70 delivered though most aftermarket ones seem to be steel rather than aluminum. work fine though.
as its a common failure point, at that price its almost worth replacing them even if the original ones are still working fine to avoid potential problems. 2010 VSE [Roger]
Post #588517 23rd Mar 2021 12:04pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I had mine replaced £128 for original TRW ones, heck the labour cost to put a fixing kit or just clean the old ones would have been more. I totally agree, considering the low cost of these it’s not worth it to mess about with them in my opinion.
I wish I could say the same for the front 🤣
Post #588562 23rd Mar 2021 4:49pm
