![]() | Home > Technical (L322) > Filling up upside down?! |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Think it’s a quirk of the filler neck, used to do this every fill on the old l322, you are not alone lol. |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Check inside your filler that the yellow miss fuel has not been tripped? It will trip if it has had a fill from a can spout inserted? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Not quite upside down but l have turned the nozzle upwards over 90 degrees ever since l have had the car, over 10 years.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
.... then check to see if the plastic reset tool is still with the car |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
If you pull it out slightly you don't have to turn it so far, there is a sweet spot between insertion length and angle.... (ooh err Mrs..!)
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Well, at least I’m not the only one then! I’ve tried the 90 degrees and no result!
I’ll try and put the tip in and go from there.... 2009 (2010 MY) 5.0 Supercharged Autobiography
watch you don't break your tool, they are brittle.... a long pozi screwdriver works alot better, if you shine a torch down, you'll see if the mechanism has tripped, it's quite obvious when you have light. |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Pull out method always a winner in this house! |
It’s worked well in this house so I’ll see if the luck continues with the car! 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
Yep, had the same with mine, and mine hadn't had the misfuel device tripped. As has said before, I think it's just a quirk of the filler neck not venting as well as it should. Bizarrely, once I'd managed to get the tank half full I could shove it all the way in and it was fine..... Phnar phnar. |
Interesting, I’ll try that too, maybe just need warming up before going in properly 2009 (2010 MY) 5.0 Supercharged Autobiography
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Never had a problem with any of my petrol fueled cars but the Diseasel fueled S max I had was a PITA to fill up. No amount of twisting the nozzle helped! I guess it was due to the tendency for the diesel to "foam" when exiting the pump nozzle. Previous cars:
