![]() | Home > Technical (L322) > My New RR 3.6 TDV8 Has Just Broken Down Turbo/ or EGRs |
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547
What year is it - maybe update your profile? - and did you map out the EGRs? 2016 Skoda Octavia VRS Estate
| theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305
It's a 2008 RR 3.6 TDV8.
Have you checked the usual culprits, intercooler hoses? 2016 Skoda Octavia VRS Estate
I had a look and didn't see any cracks. All were attached.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
Hopefully it’s not that, and something daft.
Hopefully not..
| lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59
Did you clear the codes? The EGR should in theory be isolated from the engine now, even if it fails the performance should be good and you get codes. Mine throws the odd code about one EGR bank issue, but it usually goes away on restarting. I have blanked the EGRs.
I cleared the fault codes, but currently the only ones showing is
The hoses can collapse as they weaken with age. That’s why many folk swap them out for silicone ones.
Does sound like a collapsing hose. 2009 TDV8 3.6 |
What would the symptoms of a callasped hose be like?
| Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89
If you haven't already replaced those 2x top hoses it's worth doing anyway as sooner or later they WILL split. But also if they're starting to collapse you're going to get and airflow restriction which may well explain the fault codes you're getting. You should be able to get the pair for around £120, and they only take around 20 mins to fit. |
Thanks Sam for the advice. I changed the hoses on my last 3.6 so will likely do the same with this one. Currently still none the wiset as to the problem. Once I determine the current fault I will decide what to do.
Hey Folks.
