Home > Technical (L322) > Having my leg pulled surely ?
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Hi all some advice please. Car in RR dealers for oil service, new brake pads front and rear and to look in to fault with gear box where it shunts from 2 to 1st when pulling up. Collected car last night and as I drove on the motorway the following errors appeared
HDC fault
Transmission fault
Lowering suspension
with the traction control and the amber brake light warning lamp all remaining illuminated. Stopped the car and everything reset. However when ever I went over 70mph all errors re-appeared.
So......took car back today everything now seems to be fixed. Cause / fault explained as faulty break pedal switch which must have been knocked OR became faulty coincendtally. Of course no cost to fix Sir.
Now I am no mechanic but can someone please tell me what the relationship between a break pedal switch, and the errors above might be or am I having my leg pulled ?
Ideas ?
Post #64542 18th May 2011 6:47pm
T24RES
Re: Having my leg pulled surely ?
HDC fault
Transmission fault
Lowering suspension
Ideas ?
I can't comment on all your issues. The Shunt aka 'Lurch' as known to X5 owners, is a real pain and well documented on the web. You don't mention the age or model of the FFRR. I sold my X5 because i couldn't live with the poor gearbox and didn't fancy spending a fortune on a rebuild/fishing trip.
Best of luck Ian
Post #64545 18th May 2011 6:53pm
CMJ
TDV8 07 43,000 miles
Post #64546 18th May 2011 6:53pm
T24RES
I would imagine the gearbox is different, i'm not sure. If its under warranty dont be fobbed off. Ian
Post #64548 18th May 2011 6:55pm
speedymarktd6
the brake pedal switch or one of them does control all of those functions in a round about way so yes its correct Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #64574 18th May 2011 8:37pm
ebajema
I also noticed the brake pedal switch causing all kinds of warnings when it breaks in the forums, so again the mechanic could be right. That is modern electronics for you, one tiny little switch fails and the whole thing is in ruins. Must be all the bits and bytes getting lost in cyberspace Smile
Sometimes I long back for my first car, Triumph Herald, simple so you could keep it running with a screwdriver, adjustable spanner and electrical tape Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #64593 18th May 2011 9:17pm
mzplcg
You forgot the FBH. No NOT the fuel burning heater Wink
Post #64594 18th May 2011 9:28pm
mzplcg
To hopefully add some value to the OP, I had the same lurch on the 2 -> downshift, which was actually a nasty bang if you were trickling up to a junction and decided to go for a gap. This was on my D3 V8. The cure for me was 3 things.
1. Get the gearbox ECU updated by the dealer. There is a map to help alleviate this.
2. Flush the transmission fluid as completely as possible.
3. reset the gearbox adaptives to remove any bad habits it miht have learned.
Not a 100% cure but certainly 90% better.
Some details of what I found on the web when researching this.
Subject/ConcernSubject/Concern: 2-1 Harsh Transmission Shift
ModelsModels:
Discovery 3 / LR3 V8 Gasoline Only
V8 Gasoline Only VIN-rangerange: 5A000360-6A402253
Range Rover (LM)
VIN-rangerange: 6A198058-7A263534
Range Rover Sport (LS) Supercharged Gasoline Only
Supercharged Gasoline Only VIN-rangerange: 5A900302-7A999999
VIN-rangerange: 7A100000-7A119896
MarketsMarkets: All
SectionSection: 307-00
SummarySummary:
Customer concern is:
• When the vehicle downshifts 2-1 and the throttle is re-applied, a thump is felt.
• 2-1 rollout downshift - As the vehicle comes to rest, a thump is felt.
CauseCause: Transmission software calibration issue. Suggested Customer Concern Code - P66.
ActionAction: Should a customer express concern, reconfigure the Transmission Control Module (TCM) and ensure the Engine Control Module (ECM) is on a equivalent level of software, if not, reconfigure the ECM. Follow the Service Instruction outlined below.
Post #64596 18th May 2011 9:35pm
SteveMFr
Site Sponsor
If you examine each system in detail (=read the manual), you'll see that each system has some sort of input from the brake light switch. Yes our very electronic cars are a long shot off the primitive mechanical vehicles we used to ride in - and that allows us to have power levels that used to be only supercar territory, consumption that used to require driving an econobox, safety that could not be achieved back then (DSC, SRS,etc), GPS guidance, etc, etc, etc
And don't call me Shirley.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #64657 19th May 2011 11:54am
CMJ
Very Happy I thought it would only be time before the 'Shirley' factor was mentioned.
Thanks all for comments. Looks like I should be less sceptical about garages and especially main dealers !!
Post #64864 19th May 2011 8:20pm
bogie
dosent suprise me, I had a similar array of errors over a few weeks, and finally ended up being a £17 speed sensor wire for the ABS
those brakes are wired into everything LOL Wink cheers
bogie
Post #64892 19th May 2011 9:21pm
SteveMFr
Site Sponsor
Sorry. Stupid humor. Rolling Eyes
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #64968 20th May 2011 10:25am
shirley not steve...
i like stupid humour.. Thumbs Up
Post #64973 20th May 2011 10:32am
SteveMFr
Site Sponsor
Cool
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #65028 20th May 2011 1:56pm
