![]() | Home > Technical (L322) > Tope hose collapsed or by design ? TDV8 3.6 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1344 ![]() ![]() ![]() |
Undo your expansion cap and see if the hose returns to it's proper shape. If it does try a new cap and bleed all the air out. |
Klunk Member Since: 12 Jul 2021 Location: North wales Posts: 76 ![]() |
Thanks I’ll try that tomorrow |
Is there a specific bleed process? |
Took off the expansion cap and nothing, no in rush of air, nor did the top hose open up.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
If refitted by a lazy mechanic they can be twisted slightly, this has the effect of partially collapsing the hose, move the continuous pressure hose clamp up the hose so you can twist the hose and see if that helps, do it when cold and not under pressure and any coolant loss should be minimal... |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2750 ![]() ![]() |
Are you referring to the protective sleeve over the hose not being a snug fit or are you seeing that the hose inside it is collapsing? |
The hose itself on the bottom |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
There are marks on the hose, plastic fitting and clip. All need to be aligned correctly or you run into issues like rubbing and collapsing |
UPDATE
Sorted, check the others, they may not be far behind... |
Yep, when he said it would be a 100 quid ish to fix - i said exactly that,
