Home > General > What Did You Do In Your Full Fat Today
Page 305 of 385 <123 ... 304305306 ... 383384385>
b348xyx
Baltic Blue wrote:
Good choice, they are very easy to keep clean and look well on blue cars.
Mike
Even more excited now, Looks really good on the blue Smile 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #552151 30th Apr 2020 1:35pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Pre-emptive strike on rear arches. Only light surface rust on both. Used this POR15 kit. The metal prep are all the rust and left nice shiny metal. 2 coats of paint and when dry I will finish off with Baltic blue top coat. Not necessary with trims on but I know they are black at the moment!
Checked sunroof drains and all clear.
[/img] 2011 4.4tdv8 Vogue
Baltic Blue
Post #552463 2nd May 2020 5:51pm
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Treated it to a set of 22s, ( courtesy of jakebullet a few weeks ago on here. Top bloke Thumbs Up ) and some new 285/45/22 rubber.
Suppose i best get the hose out next and treat it to a wash too !
 2006 4.2 SC
Post #552468 2nd May 2020 6:32pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Re-aligned drivers door as it didn’t sit quite right, the was up slightly which showed when you followed the lines, closes much better too now. Also turned on the DRL’s not sure if they will be any good but when I finally get to use the car again I will see how they go. Easy enough to turn off if I don’t like them
Post #552517 3rd May 2020 12:08pm
Doonhamer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Not all done in one day but in the last couple of weeks I’ve fitted a new grille and the smaller mesh grille underneath the main one, parts supplied by Powerful UK - oh, and a set of LED interior lights from them too. The difference in the lights is amazing! Cool Also been power-washed, clay barred, polished and waxed. The big fella is loving this lockdown thing! L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Suzuki Grand Vitara XL7 - sold
Mitsubishi Pajero 2.8 - part ex'd
Hyundai Santa Fe 2.0 td - sold
Mitsubishi Pajero 2.8 - sold
Post #552912 6th May 2020 1:46pm
b348xyx
fitted the new wheels, just waiting on my new centre caps to arrive. style 502 with 255/55/20
just need a good clean all dusty from sitting for ages. jetwash out tomorrow
old
changing over
new
Post #552935 6th May 2020 6:41pm
Huge improvement IMHO - the 20's look significantly better Thumbs Up
Post #552936 6th May 2020 6:44pm
b348xyx
drives alot better too ! 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #552937 6th May 2020 6:46pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Might be the yank in me but I like the before wheels. Just needed some decent rubber and not those rubber bands. Some new 285/45/22 would have done the trick....and save the 20s for winter 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #552953 6th May 2020 7:52pm
There's looks & there's ride..... the L322 was designed for 18/19/20 whereas the L405 was designed for 20/21/22 (I know there was a 19 option)
An L322 on 22's is always a firm ride - but I do agree, those tyres do look a bit on the skinny side....
I ran an L322 on 20's then 22's then back to 20's and now an L405 on 22's....
Post #552954 6th May 2020 7:58pm
b348xyx
to be honest i just had enough/fedup with the 22" i always loved the look they gave but just crap ride anything not on a motorway or smooth road.. the last year with all the country lanes i normally do daily it was just looking out for every crack and bump in road.. cracked one rim and wife always curbing them..
so i have gone for something with lots sidewall seems a comon wheel choice for l322 these days and i forgot how nice it drives with more tyre then wheel.
hopfully i can just drive the thing without the worry of damaging the wheels. Especially with my hobby going up some very crappy roads is very common and doing 2/5mile per hour and tyring to drive around all the rocks was also very annoying.
had this car 6 years now.. 3/4years with 22's and 2 with 19inch... 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #552957 6th May 2020 8:07pm
moved mine from one side of the drive to the other, just because i could. Mr. Green ... - .- -.
Post #552965 6th May 2020 8:48pm
b348xyx
Added the wheel caps Very Happy Laughing Very Happy
Post #553020 7th May 2020 12:11pm
b348xyx
On the l322 the max size tyre on a 22” would be 40 profile.
From reading before now the 45profile will also rub and require plastic underarch area in front to be messed about with. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #553024 7th May 2020 12:30pm
Spud
Absolute rubbish. It is all very much dependant on the offset of the alloy you are fitting. Just fitted 22 x 10j with offset of 50 and 285/45/22 tyres.
No rubbing anywhere whatsoever. 2006 4.2 SC
Post #553025 7th May 2020 12:36pm
