![]() | Home > Maintenance & Mods (L405) > Turbo Replacement |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2773 ![]() ![]() |
Left when looking at the engine from the front of the car or standing behind looking forwards? The right turbo when looking forwards from the rear can suffer from oil migration through the wires from the oil sensor in the sump if the blocking harness hasn't been fitted. The blocking harness is applicable to all L405 and L494 SDV8 engines and all vehicles were subject to a recall but your vehicle may have been missed. |
Pat Member Since: 20 Nov 2016 Location: Airdrie Posts: 68 ![]() ![]() ![]() |
It’s left when standing behind car |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491 ![]() ![]() ![]() |
That’s the secondary turbo then, they can be removed with the engine in situ I’m pretty sure, unless someone has rounded / damaged bolts ETC, that said either way they can be a |
Sorry to be ignorant but I’m not sure what you meant by secondary turbo any chance of an explanation or point me in right direction
Hi Pat, they have two turbo’s, a primary which is used for most driving and a secondary which only comes in when high power is required. (Above 2400 RPM under load). Very similar to a bi turbo but Called twin parallel sequential turbos for the 4.4 full fat.
Thanks Diesel Dave that is a great explanation I will have a look for any leaking joints before committing to renewing turbo |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
So how does the turbo set up differ from the 4.4 TDV8 in the L322 and the SDV8 in the L405?
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
Same. |
As DD said, but to add for simple clarity. The 3.6 had a turbo per bank and both worked equally with any amount of throttle input… The 4.4 both in TDV8 & SDV8 guise worked like train carriages ie one behind the other… First one is highly refined and does all the lower rev work (and massively reduces turbo lag) and the secondary is a wacking great turbo that’s just there for “power”… |
