Home > In Car Electronics (L322) > Voice Recognition not working following windscreen change
Charmer
Hi,
I have had a new windscreen fitted by Autoglass but now my Voice Recognition will not work.
Does anyone think it could be related?
When I press the steering wheel button there is no beep coming through the speakers, but it will begin to call the number I last called.
I have left myself a voice message using the car phone and the microphone is picking up my voice so it looks like that is ok.
When I press the R/T button I can scroll between radio channels and telephone. Unfortunately when I press the Voiice Recognition button it will only try and make a phone call, I have to press the button again to end the call as it will not respond to voice commands.
I have reconnected the battery but to no avail.
Any suggestions?
Post #606736 18th Sep 2021 2:47pm
are you pressing the correct button?
i cant think how a windscreen change would affect this. ... - .- -.
Post #606737 18th Sep 2021 3:02pm
Charmer
I am pretty sure I am.
I always used to press the bottom right button on the steering wheel with a face symbol. There would be a beep coming through the speakers and I would say "Turn Display Off" and the screen would go off and the polite lady behind the dash would say "Display Off"!
Post #606739 18th Sep 2021 3:39pm
Baltic Blue
Where is the microphone ??
Wires trapped/ cut ?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #606741 18th Sep 2021 4:07pm
the 'little face' one is the correct button for voice and a short press gets a beep..why this is trying to make a call is weird...
i can only suggest doing a battery reset, maybe this will reboot the relevant ecu's... ... - .- -.
Post #606743 18th Sep 2021 4:09pm
Charmer
Mike
Microphone is in the head lining, they did have to remove the front of the headlining when they did the windscreen.
I have checked the microphone settings on one of the hidden menus and it doesn’t look right, I have to shout for it to hear and register my voice.
I have decided to get Autoglass back to check position of microphone and ensure all connections were done correctly.
Post #606746 18th Sep 2021 5:12pm
Charmer
No beep when pressed.
I have pulled some fuses and done a battery reset but to no avail.
I am going to get Autoglass back to check the connections.
Post #606747 18th Sep 2021 5:14pm
Charmer
I have fixed it!
It isn’t anything to do with the windscreen, it is to do with the ‘new’ SatNav disc that I put in the car which I replaced at the same time as the windscreen change.
I put the old disc back in and voice control is working as normal.
I should add that Autoglass were very impressive when they changed the screen. They used a genuine Land Rover Heated Accoustic screen and also replaced the exterior pillar posts.
Post #606755 18th Sep 2021 7:31pm
ah, you never told us about the disc....
glad its sorted Thumbs Up ... - .- -.
Post #606758 18th Sep 2021 8:21pm
p38arover
Australia
How does the satnav disc control speech recognition? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #606768 18th Sep 2021 11:56pm
Charmer
Must be some software code that enables it.
Apparently 2015 Navigation DVDs are the latest version that work with Voice Recognition.
Post #607254 24th Sep 2021 9:38pm
p38arover
Australia
I noticed recently that voice recognition on my 2003 L322 wasn’t working. Faultmate indicates the module is faulty but I wonder. It’s not something I use so I wonder if it stopped when I removed the 2G/GSM* phone and did the ULF conversion.
Maybe it does have something to do with the map upgrade to 2017 maps (the latest for Australia/New Zealand).
* The 2G/GSM networks shut down in Australia a few years ago. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #607261 25th Sep 2021 1:14am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I remember when I had issues with mine & thought it was the steering wheel controls. New Sat nave unit cured the problem.
Unfortunate that you changed the disc at the same time as the screen Smile
Post #607279 25th Sep 2021 10:03am
