Home > Technical (L322) > Parking assist system stopped working
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
JayGee wrote:
Swopped out the ECU but system still dead - any fault tracing diagnostic procedure out there or even a circuit diagram?
Likely to be the multi plug pins, if any corrosion was present. Mine was very intermittent, and would report sensors all over the shop (which all checked out ok). I got a replacement plug from a breaker (from a Jag, to avoid getting another corroded plug) and replaced the pins that looked corroded. Works properly now.
Post #613434 22nd Nov 2021 6:26pm
JayGee
The plugs on the ECU? 2012 TDV8 Vogue (L322)
Post #613436 22nd Nov 2021 6:29pm
briangunn
Correct. On mine the power/CANbus plug was fine, it was the sensor one that was affected.
Post #613437 22nd Nov 2021 6:31pm
JayGee
Pulled the plugs apart and all the connectors look clean and corrosion free so looks like the wiring to the sensors under the bumpers to check next although increasingly not too bothered by a non working parking assist. 2012 TDV8 Vogue (L322)
Post #614389 1st Dec 2021 3:03pm
camaro8199
United States 2010 Range Rover Supercharged 5.0 SC V8 Santorini Black
Did you ever figure out the problem. My switch does nothing and I have already replaced the module with a used one. My module was bad and there was corrosion on the connector. I cleaned the connector metered the pins to make sure they were still good and replaced the module and still no joy.
Post #713058 1st Mar 2025 6:02am
