![]() | Home > In Car Electronics (L322) > Ignition won’t turn off, help! |
Deputy Member Since: 23 Nov 2021 Location: Maidenhead Posts: 33 ![]() ![]() ![]() |
My key in dash 👍 |
Is this a known issue?
What position is your gear shifter in? Can you hear the solenoid clicking when you press the brake pedal?
I can drive the car as normal so I can move the gear lever in any position you would normally. I just can’t turn the key anti-clockwise to switch off. It’s seized in position II, nothing else is wrong. |
Right... For the key to turn in the ignition, first the ignition needs to know the car is in Park...
Is there a cable between the ignition barrel on the dashboard, just left of the steering wheel, and the gear shifter? |
I forgot to mention that the key barrel appears to be seized in position II BUT I can pull the key out of the ignition. I was able to drive around with the engine on and key out.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Worth a try spraying wd40 into the key barrel. I know people say you shouldn’t but I’ve always done it and never had any problems. |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
Certainly, on the early cars, there is a cable that activates when the gear selector is moved from Park.
Hi John, thanks. This is very helpful. |
Think you’re correct since there does appear to be a cable between ignition and gear selector. Ignition probably doesn’t know when it’s in P but when it’s in D, how come I can pull the key out? That’s what I found confusing. Is this be a replacement part or just a repair/ lubricant application to keep it from sticking? |
Has anyone tried this fix?
