Home > Technical (L322) > Drive loss
Mr101
England 2004 Range Rover Vogue 4.4 V8 Java Black
Drive loss
Would a broken cv mean a total loss of drive? I thought centre diff would apportion drive to the rear. I ask because i have no drive and cans see front driveshaft spinning and wheel not turning. 4.4V8 L322 to keep me busy
FC101GS a toy
Series 2a Lightweight another toy
3.5 V6 24 Valve Shogun well I do need one reliable car !
Post #621730 29th Jan 2022 9:16am
chugga90
Front propshaft or driveshaft from diff to wheel?
Could be the front diff has failed? Would probably make a lot of noise along with the part rotating?
Post #621732 29th Jan 2022 9:21am
dingg1
When my front drive shaft popped out of its housing all drive was lost, so imo yes it will be your cause
Post #621735 29th Jan 2022 9:38am
Mr101
ta mate, it appears mine has self digested the cv with no prior waning so hence no drive. 4.4V8 L322 to keep me busy
FC101GS a toy
Post #621830 29th Jan 2022 10:16pm
RRPhil
The Torsen centre differential used in the NV225 transfer box can only 'bias' the torque up to a maximum split of 65%/35% to either the front or rear - it can't lock. If one propshaft sees zero torque because a wheel is spinning or a driveshaft joint has popped out of engagement, then unfortunately the other propshaft will see zero torque too.
Phil
Post #621832 29th Jan 2022 10:54pm
