Home > Technical (L322) > Restricted Performance Fault TDV8 4.4 - 1750 rpm on Motorway
Dave lincs
Same here as well
Post #632739 24th May 2022 7:07am
mjdronfield
I wonder if having the cruise on alters what gear it might be in, or will drop early on an incline where you wouldn’t normally?
Could swap it in to top using the paddles? Just to get the rpm difference out the way of your investigation, one way or the other….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #632747 24th May 2022 8:02am
JayGee
The OP stated they had used the paddles to check it was in 8th. Unless they are running very undersized tyres then the only plausible explanation is the TC is slipping or not locking. On the other hand if it was a 3.6 that rpm would be right for 70 but that can’t be an explanation can it….? 2012 TDV8 Vogue (L322)
Post #632750 24th May 2022 8:10am
mjdronfield
And the 3.6 would be in 6th….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #632751 24th May 2022 8:23am
JayGee
The OP said ‘top’. Also no paddles on the 3.6 unless they have been added as a modification. 2012 TDV8 Vogue (L322)
Post #632752 24th May 2022 8:25am
mjdronfield
Ah, apologies. Not read it all. Trouble when replying when at work 🤣.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #632764 24th May 2022 10:44am
Mike Edwards
United Kingdom 2019 Range Rover Vogue SE SDV8 Mariana Black
Suspect you guys are heading down the wrong road.
I did say “ in the low to mid 70 mph range”. I also corrected myself earlier and said the rpm was closer to 1600. Topic title also points out it is the 4.4 engine.
Post #632826 24th May 2022 10:07pm
JayGee
OK thanks for the clarification but 1600rpm still seems high for that speed - can you confirm you are running stock 255/50 tyres on your 20" wheels? Listening to the sound of your engine in the other thread I'd be looking at this as a priority for a restricted performance warning possible cause. 2012 TDV8 Vogue (L322)
Post #632834 25th May 2022 6:33am
Discotigger
Have you had a look at the 4 rubber hoses that go into the Intake Plenum, the large plastic 'donut' that sits underneath the big plastic engine cover. It's possible you have a minor split on one or more of the hoses that is allowing a little bit of air to escape from the intake, causing higher revs due to loss of turbo boost.
Take off the cover and have a good look over the hoses, see if there are any signs of soot or oil / gunk around the hoses. If you post a photo on here, we'll be able to tell if you've still got the old LR rubber hoses which have caused 99% of the problems you describe.
Post #632852 25th May 2022 10:08am
JayGee
Loss of turbo boost won't change the revs vs road speed ratio as these are mechanically locked (assuming the TC is not slipping) 2012 TDV8 Vogue (L322)
Post #632856 25th May 2022 10:24am
Mike Edwards
The noisy engine is a different vehicle.
Nothing has changed tyre wise for quite a few months.
Post #632866 25th May 2022 1:41pm
Mike Edwards
After a period where I wasn't getting any error codes I'm now getting the usual set, i.e. manifold absolute pressure and turbocharger boost pressure low.
Post #635305 23rd Jun 2022 8:11pm
