![]() | Home > Maintenance & Mods (L322) > Has anyone replaced the ABS/speed sensor ? |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Why does it need replaced? have you tried cleaning it up?
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 ![]() ![]() |
Hi,
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 ![]() ![]() ![]() |
I've managed to get the retaining bolt out ok but can't get the sensor out it is stuck solid and have tried with pliers but no joy.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
It can be drilled out fine. You find as you get the drill into it, it may free up and spin with the drill. Plus if you have your replacement you know how deep you can go
Yeh, I managed to drill it out fine using the oild one as a template and put some masking tape on the drill bit to make sure I didn't drill too far.
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
maybe you now need to remove the fault code using a obd tool i had to when i let my brake wear indicator wear all the way down "RANGEISM WILL NOT BE TOLERATED"
check the cables running up from the abs sensor, up the damper and across to the inner wing ... they can pop out from the clips and be rubbed away by the tyre. V8 or else ... |
Thanks for the suggestion, I have checked the cables already and they are all fine into the inner wing.
Hi Guys,
Interesting. It must have been out by a fair bit was it?
petewild Member Since: 14 Mar 2013 Location: Croydon, Surrey Posts: 45 ![]() ![]() ![]() |
