Home > Maintenance & Mods (L322) > L322 Sill repair panels
Page 2 of 3 <123>
johnboyairey
When I did mine (2002) I made up separate panels to weld in parts of the sill I cut out. I had to cut more than necessary as the box section that takes the jacking point pad had rusted… so I had to make a box section and get that in first against the inner sill..… then put in a folded edge sill panel, around 18 inches long, and weld that in. Then attack the wheelarch. I wish I had taken some pictures now. Basically, the sill is almost all covered with the plastic cover, so you don’t need a smooth full length welded panel, just the amount that is necessary. Also, the wheelarch behind the door doesn’t get seen either. Mine were really bad. But a good job done. Alas, a couple years later, it got scrapped as covid struck, and couldn’t get a gearbox repair done… so got another l322! This time, no rust! Might it be possible to use one half sill section, to make two end sections?
Post #649977 6th Dec 2022 1:44pm
JCW
Based on my 2007 L322, it’s really only the last 8-10 inches of the outer sill that’s needed but where it joins the inner & outer wheel arch and around the rear jacking point, the convoluted shape is the key area that would be a real help but seemingly no one’s making Big Cry
Reckon you’d sell loads if you could produce them Thumbs Up
Post #650001 6th Dec 2022 5:21pm
Chris-HGF
If anyone has a good chassis cut of the arch to sill areas required, I'm more than happy to template and reproduce them as individual repair panels.
Post #650005 6th Dec 2022 6:21pm
GraemeJudge
2004 Range Rover Vogue Td6 Java Black
Chris thanks so much for taking time and interest in looking at getting these available I shall definitely be watching with as I shall require them early into next year so shall be in contact thanks again
Graeme
Post #650021 6th Dec 2022 7:22pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Think your on to a good thing there Chris Thumbs Up
Post #650022 6th Dec 2022 7:22pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I agree with JCW. I only need about 6 inches of the sill & a couple of inches of the wheel arch. A repair panel covering those area would be brilliant. Let's hope someone comes up with a good section.
Post #650023 6th Dec 2022 7:40pm
pcourtney
Chris - this is really tremendously good news - but the trouble I reckon is going to be finding anyone in the UK with a good chassis that has not rusted to Censored
maybe someone in Spain or California might offer us some hope Smile
Post #650038 6th Dec 2022 9:18pm
Sandyt
+1 mine will be done after the winter whole wheel arch and about 8in of the sill section
Post #651285 20th Dec 2022 7:46pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Pm sent
Post #652807 6th Jan 2023 10:56pm
GraemeJudge
Any update on these panels anyone got any yet? There was a mention he might be ably to extend to the arch as well, I am in the process of getting ready to start sorting mine
Graeme
Post #658171 1st Mar 2023 1:13pm
Chris-HGF
Desperately trying to reply to the private messages I've had but I'm restricted and can't till I reach a certain post count I believe.
I don't want to spam the forum just to get this up and not seem ignorant.
Not sure if I can just reply to others posts or if I need to make my own 🤷
Can anyone offer some advice?
Post #658290 2nd Mar 2023 10:05pm
Phoenix
How's the weather in Fife today Chris? Wink
Post #658291 2nd Mar 2023 10:21pm
Chris-HGF
A bit dreich but not as bad as it could be lol
Post #658296 2nd Mar 2023 11:13pm
Phoenix
One more to go....
What thickness are these panels?
Post #658300 2nd Mar 2023 11:42pm
Chris-HGF
They're made from 1.2mm Phoenix
Post #658302 3rd Mar 2023 12:57am
Page 2 of 3 <123>
