![]() | Home > My Range Rover > Finally, A Full Fat. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Welcome....
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 433 ![]() ![]() ![]() |
Ah I see, I'll keep an eye out for tail gates then.
Suspension could be a blocked filter, does it try to go up after you lower it..? Pete
No it doesn't. Thats what my RRS does.
Huggybearfezzy Member Since: 14 Nov 2019 Location: York Posts: 20 ![]() ![]() ![]() |
Congratulations! You don't happen to own an E39 M5 by any chance do you? 😉 |
Haha yes I do. Clearly I have a problem and it can only be solved by V8s Its actually a sport |
I have exactly the same problem 😂 4.9 V8 and 4.4 TDV8. The 4.4 is the economical daily driver 🤷🏽♂️
Ah does the fbh have its own battery? I'd thought it woulda used the cars tbh but makes sense.
Sorry I meant the main car battery.
Ah I see, that migjt be a good shout because when I picked car up it needed a jump so worth seeing batt level at morning.
That's perfect ta. now it's parked just outside the house ill give it a property test tomorrow. I'll turn it on and give it a good 30mins to work. Its actually a sport |
Turns out the fob just needed a new battery.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
"Anything else I need to sort?"
