Home > Technical (L405) > Suspension Groaning when going down to access mode
Jay Porsche
United Kingdom 2017 Range Rover Vogue SE TDV6 Fuji White
I have noticed a groaning (sounds a bit like when you let brakes off when moving slowly) when I drop my daughters off to school and the suspension drops to access height. Seems only to be on the nearside.
Should I worry - its still under warranty?
Ive noticed my mates 67 plate RR sport does the same thing!
Post #663369 3rd May 2023 3:28pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Any knocking from the suspension on uneven road surfaces?
I had the same thing and also had some knocking over speed bumps etc and roll bar bushes cured mine 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #663519 5th May 2023 2:21pm
Merchy
As above anti roll bar bushes and drop links ball joints are possible causees, also on a 322 you can get a tiny bit of groaning when all is well if you drop to access height when the steering is turned over to full lock. Would imagine a 405 can do the same.
Post #663521 5th May 2023 4:13pm
DrRob
Try it without the park brake on and no foot brake. Also do it on the level and in neutral. Does it do it then? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663544 5th May 2023 9:50pm
Jay Porsche
No knocking at all its perfect whilst driving.
I dont think it does it when I put it in park.
It seems only to be when its in drive and I have my foot brake.
Post #663700 9th May 2023 10:15am
I expect that is the pads getting pulled down the disc as the car lowers, as it lowers the wheels need to move a fraction in relation to each other, in park the brakes aren't on...
Next time it does it try pressing the brake pedal harder as it is doing it, it will probably stop...
Or try putting the handbrake on and putting the gearbox in neutral, I bet it doesn't do it then either... Thumbs Up Pete
-Click here for Thread-
Post #663701 9th May 2023 10:36am
