![]() | Home > Technical (L322) > Restricted Performance - Limp Mode |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3274 ![]() ![]() ![]() |
have you had a HIGH pressure smoke test done? My Pax side inlet manifold head a minute crack in it but set off RP when I demanded power to go up a hill. |
Davidlm Member Since: 01 May 2023 Location: Taunton, Somerset Posts: 3 ![]() ![]() ![]() |
Yes, did the high pressure smoke test but nothing showed up. |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367 ![]() ![]() |
Has the MAP sensor been cleaned? quick and easy to do. I can't remember if mine threw a code up or not for it but a quick spray with some carb cleaner and it's been fine ever since. Current
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
What was the fault code exactly? 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4350 ![]() ![]() ![]() |
My suggestion. Take it to either T&S Norman in Shepton Mallet or Craig at Cam-Tech and they'll diagnose it in 10mins |
what Rob said. Only Steve at Norman's are allowed to touch my RR now. They were the only ones who took time to correctly diagnose what was happening and came up with a correct fix. MD and LR garages all failed to come up with a solution. |
I will keep their address and details in my phone for the next time!!
