![]() | Home > Technical (L322) > no low range TD6 |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
RRPhil,
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1031 ![]() ![]() |
It’s most likely to be easier to power the motor to turn it, to get the missing tooth aligned.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
"(Note that these photos were taken on a workbench so the orientation of vertical/horizontal is not exactly the same as on the vehicle)"
I would say that the photos require rotating anti-clockwise about 30 degrees to have the same vertical alignment as the transfer box installation in the vehicle. It looks to me like the motor axis is about horizontal.
Well I took newish potentiometer out of newer transfer mtoor and put it into my old transfer motor.
I understand your frustration but would urge you not to give up just yet.
Question......
I didn't disconnect the battery when removing the shift motor. Ron B. VK2OTC
Hi Ron,
It was in high range when I removed it. I used my local LR indie's hoist when it was free one weekend. Much easier than laying on one's back.
Well I pulled the old TM back off and transferred the newer poteniometer from the old TM to the newer TM as I got
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
Well done, and not too expensive... |
