Home > Maintenance & Mods (L322) > Diffs, transfer case & tranny oil service
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
lschwarcz wrote:
In my car the front and rear diffs use different fluids. The rear is the electronic locking unit and takes a special fluid.
Front: LR019727
Rear: LRN7591
So, looks like I'll get to do a bit more cleaning between components!
Thanks again!
Larry.
Please tell me you didn’t write the fluid part numbers the other way around here.
It is like exactly opposite to OP?
Is this coreect for front and rear for cars WITH rear locking difff? 12 4.4 TDV8 Vogue
Nara Bronze / Arabica / Ivory / Piano
07 3.6 TDV8 Vogue
Buckingham Blue / Sand / Piano
Post #724238 9th Sep 2025 3:56pm
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
OK, I won't tell you Wink. But, it looks like I did get them backwards!
I've edited that post and corrected it. Thanks for finding my error!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #724240 9th Sep 2025 4:37pm
Sql
Jesus today I literally picked up my car after replacing my fluids by YOUR list. So I now have them in backwards 🤦‍♂️ 12 4.4 TDV8 Vogue
07 3.6 TDV8 Vogue
Post #724246 9th Sep 2025 5:51pm
Sql
Can someone PLEASE confirm 100% what diff fluids I need for 2012 4.4 TDV8 with LOCKING rear diff? 12 4.4 TDV8 Vogue
07 3.6 TDV8 Vogue
Post #724247 9th Sep 2025 5:53pm
RRPhil
Front – Castrol SAF-XO 75W/90. Land Rover part no. TYK500010 or LRN7591. Service fill = 0.75 litres
Rear (ETM Diff.) - Originally Castrol SAF Carbon Mod Plus, superseded by Castrol BOT 720. Land Rover part no. LR019727. Service fill = 1.55 litres.
Phil
Post #724255 9th Sep 2025 8:20pm
Sql
Thank you Phil! 12 4.4 TDV8 Vogue
07 3.6 TDV8 Vogue
Post #724296 10th Sep 2025 7:26pm
lschwarcz
Sql, sorry about my error in posting. I would suggest double checking everything you read on this or any forum out there.
When researching the fluids I found a lot of conflicting data but by checking many sources including the factory service manual and Land Rover dealer websites for the right fluids only then did I finally buy and use them.
All information posted on public forums is. "use at your own risk." It's unfortunate but people do make mistakes and I'm no exception.
When reading this thread and you see I have conflicting information (reversing the part numbers), the fact that your car is a different year, different generation of the L322 with even a different engine should be enough to make extra sure the information is correct and applies to your car. All car companies change specs and hardware and even if I had not posted the incorrect information I would have suggested you be very careful about applying this info to your car.
Hopefully you now have the correct information and are successful with your servicing!
In the future I'll try to be more careful when posting information here.
Good luck!
Bournville/Ivory
Post #724349 11th Sep 2025 3:40pm
Sql
Yeah, I found it crazy confusing when reading a bunch of writeups on those diff oils. Castrol this. Castrol that, LR number this or that. Also open diff this and electronic lsd that. When I found your post consisting of simply two part numbers and knowing you had facelift electronic diff car I just copied that and texted to my mechanic.
Luckily it turns out he didn’t find fluids by LR numbers and simply used correct BOT720 (but by Ravenol) and proper 75w90 in front one.
So all good and no worries! 12 4.4 TDV8 Vogue
07 3.6 TDV8 Vogue
Post #724350 11th Sep 2025 3:46pm
lschwarcz
Hi Sql,
And just to be clear, there are three generations of the L322. I think it's 2002 - 2005, 2006 - 2009 and 2010 - 2012. Different engines in each generation but I don't know about the rest of the drivetrain.
Glad it all worked out!
Bournville/Ivory
Post #724351 11th Sep 2025 4:00pm
Sql
Sure, I know, I have 2/3 of them, a 2007 and a 2012. 12 4.4 TDV8 Vogue
07 3.6 TDV8 Vogue
Post #724363 11th Sep 2025 6:22pm
