![]() | Home > Technical (L322) > Nobody knows what is going on with my 4.4 TDV8 2011... |
Yorch1 Member Since: 29 Oct 2023 Location: Deeping St James Posts: 12 ![]() ![]() ![]() |
Was done by Glenside Motors, part of Quantum, in Linconshire |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
my 2p..... has the noise been proved to the throttle flap on top of engine? or is the turbo intercooler flap valve at bottom of the radiator doing it? is it thinking it needs to release stored cooled air at pressure to 'blow-off' ie to stop the engine.? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2767 ![]() ![]() |
With EGR mapped out that throttle plate should be horizontal. Either the remap has been removed at a dealer service or the throttle mechanism is broken. However if the remap has been removed yet the blanking plate remains fitted then the engine would try to stall whenever not on the throttle and you wouldn't be worrying about just a sucking noise as the vehicle would be basically undriveable. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
I too am thinking about the remap / EGR delete. The 4.4 TDV8 typially has well documented issues and what you describe doesn't seem to match experience of others.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 793 ![]() ![]() |
What problems were you trying to fix when you had the remap/EGR removal?
Fellas, first of all THANK YOU TO EVERYONE for trying to help.
It should perform a cycle at ignition off.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
Do yourself a favour and remove the plastic connector to the throttle - see this guide
No, the butterfly is spring-loaded to the open position so should be open with the ignition off.
Or the shaft seal has failed and there is oil ingress into the electronics for the position sensor...
General Member Since: 22 Jun 2020 Location: UK Posts: 15 ![]() ![]() ![]() |
Mine was making the same noise and I replaced the throttle body,it has been spot on for nearly 2000 miles since.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Here you go Phoenix
Well...I had an EGR problem with restricted performance. I decided to blank it to save some money but so far I have spent much much more. I really regret it. |
Is your EGR blanked? |
