Home > Technical (L322) > Do (2008) 3.6's suffer from spline wear in the drive train ?
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Asking because I have a little bit of a "thump" taking up slack from overrun or getting off throttle.
Cheers, Ard
Post #677727 11th Nov 2023 6:52pm
GraemeS
Australia
Yes, spline wear on the gearbox o/p shaft and the transfer case input shaft is a known issue and will eventually strip both shafts. They're assembled with a special grease but either the quantity of grease applied at assembly is sometimes inadequate or on some the grease dries more quickly than on others.
I had my MY12's transfer case removed at 150K kms to regrease the splines. The mechanic suggested that whilst no spline wear had occurred, the grease was rather dry and wouldn't have survived another 150K kms.
Post #677730 11th Nov 2023 8:53pm
Dutchgit
Oh balls ! Not looking forward to removing the t-box. Not looking forward to fixing the problem either ! Rolling Eyes
Post #677734 11th Nov 2023 9:52pm
GraemeS
Australia
Obviously you need to eliminate all other possibilities first.
Post #677736 11th Nov 2023 10:14pm
Dutchgit
Yes I need to spend some time under the thing anyway. I discovered a small oil drip where the rear of the lower front a-arm is attached to the engine cradle thing and I need to change the oils as well.
Post #677785 12th Nov 2023 4:36pm
