![]() | Home > Maintenance & Mods (L322) > Oil service reset |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
Hi
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
If you have a GAP IID then simply plug in and use that. It's under "Service" IIRC Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
This may be where I went wrong as the YT video I say said bonnet and door OPEN...
Might have to resort to this if the other doesn't work ![]() (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. Last edited by tymh on 4th Dec 2023 1:15pm. Edited 1 time in total |
Thanks Tym (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
To be fair, I always thought you needed the bonnet & Drivers door open... ![]() ![]() |
I ended up using IID. All done. Tym (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
