Home > General (L460 2022) > new electric range rover
Page 8 of 8 <12345678
Gremlin500
Quote:
“ What I'm not sure is, does this mean a bad battery will show itself in the first few years of use, or does it mean how the battery is treated/charged during its first few years will determine its longevity?”
I would say both. As batteries age, they not only lose capacity, but they also start to exhibit significant voltage drop under load, (which recovers to some degree if current demand is reduced), this effect becomes greater as the amount of charge reduces, so the usable range gets much lower, especially if there are frequent high power demands. For applications such as ebikes where the size of the battery can be chosen, it makes sense to purchase the largest possible battery, to maximise useful range for as long as possible. Charge rate is really important: generally there is significant correlation between rate of charge and battery lifetime, meaning the slower you charge, the longer the battery will last.
Unfortunately, the requirement for motor vehicle batteries is usually to charge as fast as possible.
A propulsion battery charged slowly at home will probably fare much better than one only charged at rapid charge points, a point to bear in mind when buying used.
Motor manufacturers don’t give a hoot, as they aren’t having to pay for replacements. Whistle V6 Vogue - “Less is More” - less to go wrong!
Post #720659 1st Jul 2025 8:52pm
JackRegan
Yes, makes sense.
A very good point about the charge rate. 2024 P550e Autobiography
2016MY TDV6 Autobiography
2011MY 5.0 SC Autobiography Black
2005 TD6 Vogue
Post #720663 1st Jul 2025 9:38pm
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
[quote="Gremlin500"]
I was just thinking exactly the same thing myself before reading this from Gremlin500 - Ask your local JLR salesperson what's the best way to charge, and I can almost guarantee that they will neither have a clue, nor care less!
Some other interesting points shared which are good to read - At least I've only ever charged slowly overnight on a 3 pin plug, so hopefully that will provide some benefit.
Post #720722 2nd Jul 2025 10:22pm
1JBS
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Interesting article about the delay to going electric -
https://www.msn.com/en-gb/money/news/jagua...c&ei=9
Post #721488 18th Jul 2025 9:25am
Mikey
Quote:
the delays may not harm JLR financially, because they will allow the company to continue to sell its lucrative petrol and diesel hybrid versions. People inside JLR have said “the delay has worked in our favour” and “let’s not rush this”, the person said
Financial decision, then? Laughing
Post #721492 18th Jul 2025 10:12am
