Home > Technical (L322) > Differentials and transfer box oil change
TomP
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Java Black
Thanks for this description and photos. All very helpful. The diff/transfer box oil was described as in need of fresh oil at 90K. Can anyone confirm the periodicity at which the oils should be changed in these 3 gearboxes? Mine were done September 2022, and I read somewhere that the oil should be replaced every 2 years. Can this be right?
Post #717562 7th May 2025 1:38pm
MC-RR
Monaco 2012 Range Rover HSE 4.4 V8 Ipanema Sand
I doubt mine was ever changed at 110,000miles. It was still in good condition when i changed it and i suppose it also depends how the car is used. I do plan to do it every couple of years however. Not too difficult to do. RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Triumph TR6 1976 - Jeep CJ7 1976
Post #717701 10th May 2025 4:11pm
TomP
Thanks, Martin. Our L322s are ageing and deserve some TLC. The bi-annual oil changes seems sensible husbandry and, as you say, not that difficult to accomplish.
Post #717768 11th May 2025 7:45pm
timl322
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Great writeup - about to do mine. When you say the drain plug on the rear diff needs a 3/8” socket, do you mean square or hex? Is it def 3/8” and not 8mm as they are different? Thanks, Tim
Post #719696 13th Jun 2025 12:40pm
MC-RR
Hi Tim,
Yes they are different, the 3/8 I used was a ratchet extension.
Rewarding job, have fun Smile RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Post #719697 13th Jun 2025 12:48pm
timl322
Thanks Martin - I’m sure I will! I take it you mean a 1/2” to 3/8” converter?
Post #719698 13th Jun 2025 12:56pm
timl322
Scratch that - I’ve just realised what you mean. Good plan! 👍
Post #719699 13th Jun 2025 12:58pm
MC-RR
That would work perfectly Thumbs Up RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Post #719700 13th Jun 2025 12:59pm
