Home > Technical (L322) > Front Blowers and FSR - Next Steps?
RovingCanary
Hello, a couple of weeks ago my front blowers stopped working (all lights and controls working fine). I read around a fair few threads and just replaced the Final Stage Resistor with a £30 aftermarket one...
It worked fine for about 10 minutes, then must have burned out as the fans came on maximum even with HVAC turned off, and then stayed on after I turned off the car.
Strangely, I put the old one back in and it it worked normally again.
I suspect there is something up with the blower unit, as it occasionally makes a little bit of noise. and a loudish droney noise if I turn it onto maximum.
Does anyone have any tips on next steps? Ideally wanted to avoid stripping down the whole dashboard , but has anyone had a similar scenario and successfully cleaned up contacts or anything? Or is a replacement blower unit inevitable Shocked
Post #685464 12th Feb 2024 6:05pm
pjw888
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Hi, lots of info on site. Normally a motor problem. There is a really good descriptive procedure on here, it may be in WIKI. For the cost of a motor, I'd just replace. I believe there is a BMW alternative at decent prices
Post #685468 12th Feb 2024 7:13pm
DrRob
Bite the bullet and get a new fan installed
https://www.fullfatrr.com/forum/topic67642.html
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #685469 12th Feb 2024 7:15pm
RovingCanary
Cheers guys, yes cheap though I think it will take me significantly longer than 5 hours! Embarassed
Will get a part ordered, hopefully it will last until the days get a little longer !
Post #685472 12th Feb 2024 7:34pm
CS
When this happened to mine there was also a need to free up and lubricate the moving parts that direct where the heated air goes, sorry to be so non-technical in the description. Only Range Rovers since 1988
Post #685474 12th Feb 2024 8:23pm
RovingCanary
Thanks CS, the duct actuators(?) seem to be working fine at the moment, however while I am in there it sounds a great idea to lubricate as well. What did you use, silicone grease?
Post #685476 12th Feb 2024 8:46pm
CS
It was done by the dealers, so I'm not sure, sorry. Only Range Rovers since 1988
Post #685477 12th Feb 2024 8:51pm
