Home > Technical (L405) > Possible Turbo issues
Page 8 of 9 <123456789>
kevinp
Ok mate. Thanks.
Just read in the workshop manual that if the car is left idling, the secondary turbo will activate every 3 minutes for lubrication. So thanks for pointing it out.
Post #717059 29th Apr 2025 11:24am
GraemeS
Australia
Faults would be stored if the valve isn't where it is supposed to be as its position is monitored, including at idle. L405 D350 SE Carpathian Grey D5 19" rims
Post #717060 29th Apr 2025 11:28am
kevinp
Yes Graeme thanks. No codes so I presume it is working correctly.
Post #717062 29th Apr 2025 11:50am
iainvr4
2004 Range Rover Vogue Td6 Java Black
comports wrote:
Hi Gang,
I think I'm getting somewhere now, although strange it still seems a little intermittent..
Have only fallen in to Restricted Performace a few times lately, seems to pull like a freight train for most round town driving but play silly Censored when already doing 30+ mph and decide to accelerate... No idea why.
Today, with IID plugged in, i tempted her into Restricted again and, without turning the engine off (which seems to clear the fault), I managed to pull the following...
This now seems to suggest a mechanical failure of the Actuator being stuck.
I pressume this is now not the secondary turbo shut off valve itself .. I think it is the thing that does the shutting/opening of that valve.?
Is it a case of 'lubing up' to free it off and see how it goes, or is it better to just replace it?
Finally - Do you think this is a Driveway DIY'er job or better to book in somewhere?
Many thanks all as always.
Hi Ash,
Did you ever get to the bottom of this? It is virtually the same story as my car. I don’t get the oil filter thing as when I checked mine there is no spring there and can’t see that someone has deliberately removed it. I have the same oil issues, drained over a litre out the intercoolers last night and the same fault codes. The turbos have been removed and tested but all ok.
Thanks Iain
Post #719389 7th Jun 2025 10:13pm
comports
Hi Ian,
Not quite sir but I think there were a number of issues (possibly related) on mine.
The oil loss was a big one as I lost 9+ litres in a couple of months.
If you take out the oil filter you will likely not see much in the bottom there - I suspect it will have a fair amount of oil in the base. Use old rags or paper towel to soak up as much as you can. Although its called a spring, its more like a spring loaded clip (KevinP's pic is the best view https://www.fullfatrr.com/forum/topic70038-45.html) and should have a rubber bung located on one side of it.
If you are losing that much oil I will bet the rubber bung is missing or dislodged, no longer covering the drain back hole. Its a very simple fix but you'll need to find someone with a spare spring/clip.
My oil issue was completely solved by replacing mine and not used a drop since but I still need to get underneath and take the under tray off to check the actuator movement and possibly the wiring - I suspect with all the oil around the area, things might just be rather gunked up but I do still go into restricted performance but only if I 'hoof it'. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #719398 8th Jun 2025 9:28am
iainvr4
Hi Ash,
I’ll have another look at that, when I looked at mine before it didn’t have the plate at all so took it as a change in design. But after reading loads of posts I looked at the part numbers and they haven’t changed. The car got the oil cooler gaskets done at Christmas so wondering if something has happened then. I have the same turbo faults as well with it going to restricted performance which I think I am narrowing down to the sensor sticking on the shut off valve on the 2nd turbo. The valve is moving ok but when you drop the vacuum off it the sensor is still showing it as open. I took the 2 turbos off and got them tested and came back all ok. Just a total pain. Thanks
Post #719399 8th Jun 2025 9:55am
comports
Oooh - wait 1... Your profile shows a 2004 TDV8..? If thats true, the set up might be completely different.
Do you have an inverse fitted oil fiter, i.e downward facing ..? That spring and hole in the oil cooler housing is to allow drain back of oil from the filter when removing, presumably for a filter change.
Did you remove the engine to retrieve the turbo's I don't believe thats possible/easy on the L405s.
I want to check my actuator but have no idea where to start - will jack up and axle stand the front, remove the front under tray and go for there I guess. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #719401 8th Jun 2025 10:48am
comports
Thank you Ian for giving me the nudge to go take a look at mi e to see if I can get closer to the issue.
So, after jacking it up, axle stands in place and wheels off for better access, I removed the metal undertray. At first I struggled to find what I was looking for so made myself a brew and scratched my head. A quick ready through this thread and NorthernMonkeyJones’ post on page 3 set me straight.
Thanks quickly found said secondary turbo actuator from underneath - and it’s quite obvious when you spot it.
I couldn’t move it by hand (it’s a little difficult to reach anyway) but then, using an extension bar, I managed to reach the arm/ball and it did move, a little stiff at first but after a liberal dose of WD it was better - however, I did notice a few times it did not return to ‘normal’ (closed) position and required a jiggle to free it off….
I went for a quick spin and she went up through the rev range to past 3,500 and changed up and up again but when I backed off she tripped into restricted. 😩😡
Given the last error code I got was ‘Turbo actuator valve stuck high’, have I hit the nail on the head here..?
If so, is this indeed a repair kit job or just a straight replacement. ??
Thanks all for sticking with me..! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #719418 8th Jun 2025 3:57pm
iainvr4
Hi Ash
It is a 2017 4.4 I have just not updated my profile on to my 3rd RR. It was possible to remove both the turbos but did need a lot of patience there is a few really tricky bolts to get out and you are essentially working with only one hand and it took me a bit of time as I only managed an hour or so after work in between the bad weather as the car was on stands in the drive. Mine is doing the exact same as yours when you drop off the boost that’s when the light comes on. Checked it with live data and it was showing at 100% when it should of been 0% I’ve stripped the sensor out it and about to try it with the live data to see if I get a lag. The valve is moving totally free unless it is when it warms up it sticks the mechanical parts is soaking just now to free off any carbon. I’m not sure what the script is with the oil filter as surely the plate can’t be missing as it you’d think when they done the cooler they would have noticed. I can’t see any difference in part numbers although there is a supersession so would if that’s the change. I’m not sure whether to order one and then just compare the 2 of them. Thanks
Post #719429 8th Jun 2025 7:01pm
iainvr4
kevinp wrote:
Have a look at these pictures.
First shows valve correctly fitted.
This is with the valve missing.
Looks like yours is fitted. Just check the rubber bung is in place and not missing.
Did they change these on later models? I have an oil issue similar to the OP check my filter housing and there isn’t a plate there nor a rubber grommet. Thanks
Post #719430 8th Jun 2025 7:18pm
iainvr4
Here is the picture of it
Post #719431 8th Jun 2025 7:19pm
comports
Apologies Ian. Was going off your profile.
Just a thought Ian,
I won’t drive it for long like this but if I unplug the MAF sensor on the right hand air intake mine doesn’t trip into restricted. You could try that in conjunction with your live data to see if it make any difference or you get a different reading?
Cheers Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #719432 8th Jun 2025 7:20pm
comports
Yours should look like the top pic. The bottom one is with the clip/spring removed. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #719433 8th Jun 2025 7:23pm
iainvr4
Just now mine looks like the bottom one 🤦🏼‍♂️
Post #719434 8th Jun 2025 7:26pm
iainvr4
The concerning thing is where the hell has it gone and when???
Post #719435 8th Jun 2025 7:29pm
