Home > Maintenance & Mods (L405) > Park Assist using IidTool
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Interesting also to see if and how LDW can be changed to LKA...
Post #716998 28th Apr 2025 4:51pm
adara
I managed to enable Lane Keep Assist! This IIDTool is incredible!
The required steps are:
-EUCD-098 Lane Departure Warning = LDW Fitted with Enable Menu & TSR Fitted with Overspeed
-MultiCAN-498 LaneKeepAssistLKA = LKA fitted
-EUCD-026 Power Steering Type = Electric Power Steering with external angle and torque control , only for JLR
After which I ran: IIDTool Menu / Service/Test / IPMA-Image Processing Module ‘A’ / Allow Central Configuration Data Learning
Will need to check while driving over 37 mph (and under 112 mph), but it is present in the menu now:
Post #717045 29th Apr 2025 9:36am
adara
The journey of discovery continues! I found the settings to enable the Adaptive Driving Beam. Up until now, I only had access to the Auto High Beam option, which worked well by dimming the lights for oncoming vehicles. But that got me thinking—what exactly is the advantage of Adaptive Driving Beam? The manual doesn't explain it clearly.
Post #717067 29th Apr 2025 1:46pm
goodknight
Have you been able to activate steering assist as well as lane keep assist using those settings? I can see from the screenshot that steering assist is present.
Post #717182 30th Apr 2025 9:16pm
adara
The submenu before was just Land Departure Warning with on or off, it has changed after the activation to LKA with vibrate or assist, but I have yet to check if it really assists, as in town it is impossible to use (speed too low)...
Post #717193 1st May 2025 7:21am
is it a G4 iidtool version you're using? ... - .- -.
Post #717195 1st May 2025 8:08am
Mine is a G3 Stan Got - 2017 SDV8 Autobiography in Loire Blue
Post #717204 1st May 2025 10:48am
adara
Yes, Stan, the G4, it’s an awesome tool!
Post #717206 1st May 2025 10:56am
thanks for that adara.. Thumbs Up
G3 is up to 2018 i believe . ... - .- -.
Post #717211 1st May 2025 11:14am
goodknight
Did the changes work for you ie. Lane keep assist and steering assist?
Post #717648 9th May 2025 11:09am
adara
Being away from the car, I simply didn't have the opportunity to check, but will do this weekend...
Post #717660 9th May 2025 5:49pm
adara
I finally had the opportunity to test Lane Keep Assist, and it does work. Once the car exceeds 60 km/h (37 mph), the lines on the dashboard turn green, and the system begins to correct the trajectory. You can even remove your hands from the steering wheel for up to 10 seconds. However, I’m not sure if it's supposed to function this way—it doesn’t keep the vehicle centered in the lane. Instead, it swings from one side to the other, only activating when approaching the edges. That said, it does its job.
Post #717779 12th May 2025 6:34am
