Home > Technical (L405) > Locked In Drive, Engine off,
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
Hi , need some helpful advise.
Pulled up a mile from home, engine running, couldn't select park, turned engine off, rotary dial still up.
Can't select park to start engine, dial still up?
What does anyone know?
Post #716901 27th Apr 2025 3:51pm
mjdronfield
I’m pretty sure that under the bottom of the cup holder there is a red lever thing that if you pull it it puts the gearbox in neutral. That said, hopefully the issue you currently have won’t stop it working.
Hope it helps. Others who have had the exact issue may have other ideas.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #716913 27th Apr 2025 5:48pm
goldeneye32
Cheers, we've found that already, suspected drive selector solenoid issue.
They are on Ebay second hand for about 150-180
Post #716914 27th Apr 2025 5:51pm
mjdronfield
https://www.fullfatrr.com/forum/post706405.html
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #716915 27th Apr 2025 5:51pm
mjdronfield
Ah, ok, so figured then you can get it in neutral to start engine but can’t move gear selector. I’m stuck with that one without more forum searching, not had that issue I’m afraid.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #716917 27th Apr 2025 5:53pm
goldeneye32
So, Here's an update if you have an L405 made before 2016, apparently the electronic motorised gear selector can be re-furbished, there are a handful of companies in the UK that do it, you just have to get it out and send it to them.After 2016 they are a sealed unit.
After contacting a couple of wannabies from Ebay , although the guy in ESSEX seemed to know his stuff, my local Indy has taken control of it and using someone they know who does it, about the same price, all in, including removal and refitting £400.
While the drive is out it gives me the opportunity to address the 'razors' edge cup holder drawer.
Post #717000 28th Apr 2025 5:13pm
goldeneye32
So, motorised drive repaired and refitted(£356), I purchased some foil tape, to repair the razor edge of the cupholder sliding tray, but it looked a bit naff, and I managed to break off a couple of the plastic rivets that hold the trim down, so I thought, WTF, get the whole thing off, leaves a 2-3mm gap around the whole tray, but luckily mine has no damage to any of the edges, and personally I think it looks pretty good!
Post #717749 11th May 2025 11:53am
