Home > Technical (L405) > Range sdv8 doesn't go over 2000rpm.and shut down
Page 2 of 3 <123>
Jass786
United Kingdom 2013 Range Rover Vogue SE SDV8 Barolo Black
Post #718011 15th May 2025 9:54pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
So the original stud had failed and has already been replaced, wouldn't hurt to remove the cabling from the new point and check it all over.
Have you got a sunroof? Have you checked for leaking drains (wet carpets etc)? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #718012 15th May 2025 10:05pm
Jass786
Hi
hi where does that turbo pipe connector connect
It,s not connected can't find where it connect
Thanks
Post #718016 15th May 2025 11:03pm
Jass786
Any help thanks
Post #718365 22nd May 2025 5:14pm
4RRS
Turbo boost pressure sensor more or less vertically above it, it's tucked away under the manifold from what I remember. If you can find it, follow the wiring local to that area as there is a connector going to it. It's made of quite brittle plastic and the hose can snap off. Have a look in the end of the hose to see if it snapped. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #718366 22nd May 2025 5:20pm
Jass786
Hi can't find have you got any pictures thanks
It could be reason doesn't go over 1500rpm
Post #718458 24th May 2025 9:09am
4RRS
9F479 on the diagram
https://parts.jaguarlandroverclassic.com/p...and-rover/
Just look at the hose and it'll be above the end, it's tucked away admittedly. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #718459 24th May 2025 9:18am
Jass786
Does this cause engine to shut down thanks
Post #718468 24th May 2025 12:18pm
4RRS
It monitors secondary turbo boost pressure so it's definitely not going to run correctly without the sensor connected. Did you find it? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #718478 24th May 2025 1:50pm
Jass786
Can't find it
Thanks
Post #718479 24th May 2025 1:51pm
4RRS
Was that last picture you posted when the engine was out of the car or is it not of your engine?
You'll probably need to remove the 2 hard plastic fuel lines from the left side of the fuel cooler that run alongside the right hand cylinder head and the ace fluid reservoir and maybe the airbox to get close to it as its tucked under the cylinder head. It's mounted with the pipe nozzle facing down and the cable connected to it clips to the cylinder head just behind where the vacuum solenoids are fitted. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #718480 24th May 2025 2:07pm
4RRS
If the charge air pressure sensor (the one you are looking for) is not connected the engine will not detect secondary boost pressure and the engine will operate in mono turbo mode and set a reduced performance error.
You have a DTC P010C-00 that references back to this, so it's definitely your problem. It wasn't in your first scan though, did something happen in between scans relating to this area of the engine?
If the engine was removed and the secondary turbo outlet pipe was left dangling without any support it's highly likely that the nipple will have snappped of the sensor. Maybe it would be a good idea to give us a bit of background to the story??
Just checked the WSM and you need to remove the AC pump to gain access to the sensor, see pics
below: -
Post #718485 24th May 2025 2:43pm
Jass786
Hi connected the Turbo boost pressure sensor
Now rev doesn't go over 1000 and shut off
Thanks
Engine was removed and rebuilt
Post #718496 24th May 2025 4:43pm
Jass786
Any body thanks
Post #718662 27th May 2025 7:43am
4RRS
I think it would be useful to all if you gave us a bit of background to the car rather than one liners all the time. Secondary turbo charge air sensor hoses don't just fall off... L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #718663 27th May 2025 7:51am
Page 2 of 3 <123>
