![]() | Home > Technical (L322) > 322 n62 oil pressure light |
Shook1 Member Since: 19 May 2025 Location: Maine Posts: 3 ![]() ![]() |
Oops Christian. 😆 |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1584 ![]() ![]() |
Small correction to your typo. It's an M62, not N62. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Just to check, the L322 M62 has a remote oil filter housing that, if you look in the engine bay, is behind the top right of the radiator. It takes a 'paper' style cartridge inside it which sits around a removeable plastic centre as seen here:
The socket size for the oil filter cap is 36mm. The oil filter you need is the LPW500030 like this:
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
I had this on tickover. Best solution was to drop the sump plate, remove the pickup and strainer, and clean the strainer using a sharp pick. If the guides have previously gone then there will be bits in the strainer restricting the oil flow. Easy job to do.
The other things you may need are the filter housing rubber mounts. They do fail and tear apart leaving the oil filter housing hanging. 2 off part no. LYD000010 https://www.roverparts.com/filters/oil-fil...zNDw8QawqM Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
Change your filter for a MANN filter
