Home > Technical (L405) > Range Rover L405 Fuel Tank Cradle Compatibility
Yes, it was a good second hand one, sandblasted and hot dip galvanising and it cost about as much as a new one (not that you can buy a new one anymore)
Should outlive the car Thumbs Up Pete
-Click here for Thread-
Post #719246 5th Jun 2025 9:29pm
fisha
Any idea on what thickness is the steel sheeting on the d shield ? V8 or else ...
Post #719260 6th Jun 2025 7:47am
I would guess around 2mm, certainly nowhere near 3mm, could be as low as 1.5... not very helpful, sorry, you can lift it on your own, it's difficult to pick it up because of the shape but the weight is OK
I don't think the thickness of the metal would interfere with fitting, there is leeway on the mounting holes.
There are tabs with M6 captive nuts, that hold heat shields, added in various places, mostly around the "hump" area.... Pete
Post #719294 6th Jun 2025 11:54am
