![]() | Home > Technical (L322) > Brake flaring tool specifications for 2012 TDV8 Westminster |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 802 ![]() ![]() ![]() |
I wonder if anyone can confirm the size/type of brake flare tool required on a 2012? I suspect it's 3/16 pipework and a 4.75 DIN flare but thought best to check first.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 233 ![]() ![]() ![]() |
Here is a link to Joe90's guide to the brake lines, I did mine, a 2010 facelift a couple of months ago and it is a brilliant guide.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
FFRR has DIN flares and fittings, at the time, I got away with using SAE flarings (I now have a DIN flare tool). .
Thanks for the comments chaps!
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3881 ![]() ![]() ![]() |
Did you take any pictures of the fuel tank cover that you can share?
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 306 ![]() ![]() ![]() |
I’ve just finished replacing my front to back hard lines with braided lines having done quite a bit of research on them. The advantage is that the flexibility of braided lines means that you avoid having to drop the subframe or make up any din flares. I’ll post a full write up in the next few days with all the info. for those considering brake line replacement. With the fuel tank cover; the trick is to drop the front down first so that the cover clears the two threaded spigots adjacent to the prop shaft and then when the cover has dropped rotate it laterally so that the front goes in toward the prop shaft and the back squeezes past the rear subframe mount. A bit of elbow grease is required but I didn’t have to fight it ! Sam’s motor and machine just posted a useful video that includes brake line replacement here : https://youtu.be/ET8b2JXhD0o?si=VkbNMYB1JUJcrj-A TDV8 4.4 2012 |
There are some pictures, in place and off the car in my brake pipe guide. No it does not support the tank. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Took a couple of photos for you Mike. Gave it all a wash first - not just for aesthetic purposes - it was to avoid filling my eye sockets with dust and crap when it comes to re-installing them! The cover is what it says - a cover! The tank has a separate securing strap and the cover doesn't support the tank in any way.
Thanks for pictures
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 70 ![]() ![]() ![]() |
What length braided hoses did you buy please. Thanks |
