![]() | Home > Maintenance & Mods (L405) > L405 Battery Change |
| 4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 457
Enable protected functions is a bcm setting that if for say you have a short on a vanity mirror supply, the bcm shuts the power off to that circuit as it is unfused, enable protected functions would re-enable the output assuming the fault was cured. You only need to run this if you have a dtc stating that a protected function has been disabled.
| Eddthedoc Member Since: 07 Jan 2024 Location: Norfolk Posts: 12
Thank you so much for the clarification this is a Gen3 iid tool.
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6838
What version of firmware do you have on your Gap tool? It might need an update. I didn’t have a few features on mine until I did an update and as if by magic, they all appeared |
The device was running the right firmware but the battery reset function is in a different menu to The BCM as was in the manual.
Glad you got it sorted.
