Home > Maintenance & Mods (L405) > Sv 2018 seat module
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Sv 2018 seat module
Anyone with Topix have details on the removal of the driver seat?
I need to get at the seat module out for exchange?
Post #720102 20th Jun 2025 5:28pm
zenman63
Well fitted a new seat module, easy enough job with just 4 bolts and lean the seat back enough.
Now the problem with fault codes has gone but unit need calibrating.
Looks like a dealer job?
Post #720456 27th Jun 2025 6:02pm
Kot
Will this help?
https://www.diagnostic-associates.co.uk/do...ration.pdf
Edit-- just seen this in wsm
INITIALIZATION
When a replacement of the or DSM PSM is installed, it should be calibrated using the JLR approved diagnostic equipment. 2018 SE SDV8 4.4 Byron Blue
Post #720459 27th Jun 2025 6:41pm
zenman63
Thanks for that, dealer level diagnostics, nothing easy anymore.
I will let you know how it goes.
Post #720476 28th Jun 2025 9:50am
zenman63
Well managed to get the module coded and it’s not fixed the problem so need help, Topix would help or a tec at Lear that can change the frame, it’s so complicated and buried in the seat.
Warranty doesn’t want to know.
Post #720644 1st Jul 2025 6:58pm
What is the problem your trying to rectify sir?
Post #720666 2nd Jul 2025 1:26am
zenman63
The massage seat doesn’t work and the seat frame with the motor and valve needs changing.
So it’s seat out and strip and re build.
Post #720668 2nd Jul 2025 7:10am
zenman63
Weekend job to change the massage unit, just picked it up, over £600!
So I had Topix access and it’s hard to use when you have no idea.
I need to remove the head rest and rear screen and the speaker grill so I can get the cover off, looks a mission.
Any help with info.
I plan on making a video, must be very common as this part was stock at the dealer.
Post #720754 3rd Jul 2025 5:58pm
zenman63
Well seat came out easy enough with two people and it came in the house for strip down, couldn’t get the head rest out so gave up there and it’s not a problem.
Came apart well and some bags were still inflated.
5 hours later it’s back in the car, had a minor issue with closing the tailgate with the battery disconnected!
12 volt battery under the bonnet on the jump terminal fixed that.
Not tried it yet as it’s just back in, still have the screen to re fit.
Post #720904 6th Jul 2025 9:29am
zenman63
All back together and working properly,
£620 for the massage frame £450 for the module, £100 coding and free labour, resulting in massive saving from Land Rover quote of £2500.
Post #720914 6th Jul 2025 2:21pm
Kot
Thumbs Up good write up. but very brave working in bare feet Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #720930 6th Jul 2025 5:47pm
