Home > Technical (L322) > 4.4 tdv8 Westminster reduced performance
Joff1961
My first post so be kind.
I have been trying to find out why I am getting reduced performance for a few weeks now, I’ve been looking at all the post I can find. Code reader is saying it’s the turbo actuator on turbo B. Things I have done so far
1. Renew donut to inlet manifold x 4
2. New vacuum pipe to actuator
3. Smoke test to look for leaks ( none found)
4. Vacuum test on actuator
I did order a new actuator but the one that was sent was not the same as the one fitted, the one fitted looks like it is fitted with 3 torque screws from the top and location is between rad fan and front left of engine. Does anyone have the part number for the actuator. Thanks for any help.
Post #720185 22nd Jun 2025 2:16pm
Baltic Blue
Does the car bring up the Restricted Performance alarm at any specific engine revs, notably 2500 rpm ?.
Type CSOV in search and have a read. 👍
Post #720188 22nd Jun 2025 3:13pm
Joff1961
Yes about 2,500 revs and goes away when you turn the engine off
Post #720189 22nd Jun 2025 3:29pm
ashtrucker
Have you done an oil change recently 2012 Westminster 4.4 tdv8
Post #720191 22nd Jun 2025 4:03pm
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
I have had the same issue and also the issue with a sticky CSOV.
I had a new secondary turbo actuator fitted at a specialist which cost me approx £340.
I lubricated the CSOV from above using a high quality (ZX1) lubricant and a long tube to avoid a mess.
I know make sureI use the secondary turbo on every drive where I can get the engine to operating temperature for at least 5 minutes so the oil is at temperature and not just the coolant (which heates up much quicker than the engine oil).
No more issues. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #720192 22nd Jun 2025 4:12pm
Joff1961
I do an oil change every 5K, this all started when I did the oil cooler so had the donut off and all was fine then had it off again to check for any leaks but had none but do have a very small weep from the new fuel filter I put on. I must of moved something but can’t find anything. Will just have to keep checking until I find it.
Post #720194 22nd Jun 2025 4:43pm
ashtrucker
Reason I asked about oil change is I had the same kinda of issue mine turned out to be the oil drain leaf spring in the bottom of the oil filter housing hand come loose and oil was permanently draing out of the oil filter houseing 2012 Westminster 4.4 tdv8
Post #720195 22nd Jun 2025 4:52pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
I had this after getting the oil cooler done but my problem was that the two pipes at the front of the engine had slipped off. If you’ve already replaced one of them, it’s unlikely to be the same problem for you.
Post #720203 22nd Jun 2025 7:16pm
Joff1961
Ok I think I have found my leak, not vacuum but pipe that comes off the turbo cross over pipe and goes to left side of engine and bolts on
It’s coming from the joint area we’re it connects to the cross over pipe can’t see if the pipe has a split in it or not but I have an exhaust gas leak from. Can anyone tell me the name of that part and the part number if possible please.
Post #720242 23rd Jun 2025 2:11pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Any use?
https://parts.jaguarlandroverclassic.com/p...and-rover/
Maybe worth disturbing the heat wrap to make sure the gasses aren't channeling up from lower down, could then be a cracked cross over pipe. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #720248 23rd Jun 2025 3:26pm
Joff1961
I can feel it coming out the joint by the clamp, I ordered the joint for the other end with the two bolts on it LR022775 but can’t find a number if it has a joint/seal on the clamp end.
Post #720252 23rd Jun 2025 4:40pm
Joff1961
Looks like I need a new link pipe, anyone got a part number
Post #720253 23rd Jun 2025 4:43pm
Have a look on the web link posted above, it’s the JLR parts catalogue for the 322. Pretty easy to use and all pictures.. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #720258 23rd Jun 2025 7:07pm
Joff1961
Thanks for the reply, I have now found the part number which is LR022840, Maltings have them in stock
Post #720259 23rd Jun 2025 7:09pm
Joff1961
Now fitted new part and no gas leaks, but when I took it out for a test drive I’m still getting the same code. So I think I will take the vacuum are off the actuator and do a vacuum test on that and see what happens also do a few push tests on it to see if it stick at any point. That’s the cheep part of the job Laughing Laughing
Post #720447 27th Jun 2025 1:56pm
