![]() | Home > Maintenance & Mods (L405) > SV transmission service |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
A simple drain and refill is fairly straight forward on the ZF boxes. But afaik changing the filter is trickier as you have to drop the transmission crossmember. To get the pan filter off. Definitely worth swapping the fluid out.
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 216 ![]() ![]() ![]() |
Thanks for that, is there no way an air line would push the oil out the cooler and tubes? |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 180 ![]() ![]() ![]() |
The issue you have is the cooler is thermostatically controlled and opens at 82*C so you can’t just ‘blow’ the oil through the cooler. The only way to do a full flush is with a machine, otherwise it is just a case of drain and refill and a short drive before repeating a few times to get almost all the oil changed. |
Thanks for that, I understand more now. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
Search for bodsey on the forum.. ... - .- -.
