![]() | Home > Maintenance & Mods (L405) > Sunroof Drains |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
Maybe one for the L405 folk ? |
sullivj Member Since: 19 Jun 2025 Location: Gatwick Posts: 57 ![]() ![]() ![]() |
Apologies - I’m new here!
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1525 ![]() ![]() ![]() |
Evening Sullivj,
Thanks DRF.
dpm Member Since: 14 May 2018 Location: grimsby Posts: 48 ![]() ![]() ![]() |
Checked mine last weekend after seeing the horror stories that blocked and rusted drains can cause luckily mine were clear. Got a syringe and a bit of small bore pipe and pumped a load of water down the drains to make sure all clear. Only need to take the black inner roof trim off to expose the drains fully. |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 200 ![]() ![]() ![]() |
These are not the drains, and that’s not the trim that you need to remove. You have lifted the trim that hides the fastenings for roof rails. The next piece of trim nearest to the sunroof is what you need to remove to expose the drains. |
Good spot, yes it's the next bit of trim, if you open the roof you should see them. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1173 ![]() ![]() ![]() |
Yes I made that mistake on mine and it broke two clips. overfinch modified |
