![]() | Home > Maintenance & Mods (L322) > Smoke in Engine Bay NSF |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1010 ![]() ![]() ![]() |
have you recently changed the oil filter ? |
JedY Member Since: 29 Dec 2024 Location: Burnley Posts: 20 ![]() ![]() ![]() |
I have but the problem has been occurring for a few months. I thought it might be oil leaking from the oil cooler and hitting hot pipes and producing the smoke. I've since changed the cooler but the problem persists. I've changed to the oil filter twice. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. |
Ps. Ive just done a smoke test (my first time!) Via the left air filter pipe and the MAP sensor. No leaks detected....if I've done it correctly of course... 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. |
just do a quick check for me, carefully remove the oil filter, look into the bottom of the oil filter housing, and see if the the flimsy metal spring clip has moved or been dislodged, this can easily happen when doing a simple oil change |
Thanks. Will do and report back. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. |
The photo below shows the tiny ( about the size of a 1p piece ) , rubber valve that opens when you remove the oil filter, circled in red, if it is not seating properly when you refit the oil filter, you will have oil being drained away unecessarily
Agreed! Please see picture 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. |
yours looks OK, the rubber seal seems to be centred OK over the escape hole, can you see it ( feel it sealing ) when you carefully push down on it with the end of a small screwdriver ?
Thanks. I'll check that 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. |
Yes, all seems good 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. |
