![]() | Home > Technical (L405) > And another SDV8 failure... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8105 ![]() ![]() ![]() |
Not too many options, but covered in this thread - https://www.fullfatrr.com/forum/topic73894.html |
seamus Member Since: 20 Jun 2021 Location: West Sussex Posts: 9 ![]() ![]() ![]() |
Thanks, I had found that link but not sure it really says anything I haven't touched on already.
It is slightly worrying that after years of being seen as more robust than the 3.0 that there seem to be a steady stream going pop. |
noone Member Since: 05 Apr 2025 Location: Florida Posts: 95 ![]() ![]() |
Would you mind sharing how many miles were on it when you obtained it, how many previous owners and how many miles were on it when engine failed with you owning it? 2023 L460 Range Rover SE P400
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 265 ![]() ![]() ![]() |
Not sure miles is massively relevant. Oil change intervals is probably a much better indicator. |
SparkyMark837 Member Since: 01 Mar 2025 Location: West Sussex Posts: 6 ![]() ![]() ![]() |
Just reading your original post are you saying that you last changed the oil 5K miles ago but have just changed the coolant pipes? |
