|  | Home > Maintenance & Mods (L322) > 2012 No Trailer Lights |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | I can't help much with the wiring fault but I do know the 2012 doesn't have the same trailer ECU as the earlier cars.
|  20th Jul 2025 11:28pm |
| V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381      | Trailer lights are wired independently Ona 7 pin socket, should be brown and black to no 5 and 7 pins. If both not working does point to the wiring unit on the trailer. Easiest option is to disconnect and insulate the two wires from the socket and connect a new live feed from a rear light. If you have a multimeter check the old wires to eliminate an unlikely failure in the new socket. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
|  21st Jul 2025 9:40am |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
