Home > Technical (L460) > Pivi Pro Software Update v4.3.1 fails to update every time
Hoyboy
Prior to this update I’ve had around 6 previous updates which have installed perfectly every time without a single issue.
For some reason with this update the car just refuses to install it. The message says “The update has been downloaded and is ready to install” every time I turn off the car. If I click “Update now” it says the usual message about closing all windows, locking and alarming the car and leaving it to install for at least 35 minutes.
Every time I do this before I go bed, the next day when I start the car it just keeps saying there is the same update ready to install again. It’s gotten to the point now where even though I’ve done a 2 hour round trip down the motorway the night before, a “Battery low, please start engine” warning comes up in the morning.
Is there anything I can do to force this update to install? The message every time I turn off the car and the battery low warnings every morning are starting irritate me.
Car is MY24 FF Autobiography.
Thanks.
Post #722383 5th Aug 2025 9:20pm
DrRob
I’d call LR Assist out Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #722384 5th Aug 2025 9:33pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Have you fitted an immobilizer or any other electrical thing since, my NoGo had to be switched off or it failed letters not necessarily in the right order
Post #722403 6th Aug 2025 1:21pm
Hoyboy
Nope, nothing changed since the previous updates.
Post #722404 6th Aug 2025 2:39pm
Hoyboy
Do they actually deal with things like this? Thought they’d just fob me off to a dealer
Post #722405 6th Aug 2025 2:40pm
AndyS
They will deal with these issues I’m sure but maybe good to say you’re dealer can’t look at it for weeks. Make sure you also get a LR tech out rather than a normal RAC employee who know nothing about these cars. Current fleet:
2020 McLaren 600LT Spider
2020 Mercedes C300 Cabriolet (sold)
2023 L460 PHEV 440 SE
2021 Toyota GR Yaris
1992 Lotus Esprit turbo
2019 Alpine A110 (French rubbish now gone)
Post #722441 6th Aug 2025 10:23pm
Pajo
Australia
I have had my pivi updates fail to install when my RRS p460e is parked in my garage due to weak wifi/mobile signal strength in that location. It seemed to be able to receive the update ok in that location but not install it. My solution was to park closer to the house where the signal is stronger and I then have no problem, all updates install first time every time. Might be worth checking that something is not going on with your wifi/mobile signal and trying the update where you have strongest signal.
Post #722469 7th Aug 2025 12:50pm
Hoyboy
Slightly confused with this. Car is parked on the driveway in the exact same place it was for all the previous updates. It has never been connected to the house WiFi or used my phone signal to install the previous updates and they installed perfectly so not sure why this would be a factor now?
Post #722476 7th Aug 2025 2:51pm
tonypjr
United States 2019 Range Rover Vogue SE 5.0 SC V8 Santorini Black
Have you tried doing a reset on the Pivi Screen. Reset all settings?
Post #722481 7th Aug 2025 3:37pm
