Home > In Car Electronics (L322) > L322 2010 android headunit rear screen function
theJAFman
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Baltic Blue
I just found this on AliExpress:
£507.82 | For Land Rover Range V8 L322 2005-2012 Car Multimedia Video Player Radio Gps Navigation 10.25 Inch Android 13 octa core 8+128GB
https://a.aliexpress.com/_Ew3xkKm
Looking to buy one of these it works with oe reverse cam and 4x4 functions
Im yet to collect my car can anyone advise the if the rear headrest screens work independently or rely on the front original headunit?
Thank you in advance
Post #722902 15th Aug 2025 1:37pm
exyjerome
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
These Android head units aren’t fully compatible with the rear entertainment system. I installed one - rear screens didn’t work, and while the 4x4 info was available, it wasn’t the OEM version. If you have the 360 camera, accessing it on these units can also be tricky.
£507 is very steep for that unit. I paid £265 (including import taxes) for the 8-core / 4GB model here: https://www.aliexpress.com/item/1005007948754695.html
For reference, you can see the 4x4 info in this thread: https://www.fullfatrr.com/forum/topic72928-45.html
If you’d prefer to keep the original head unit but add CarPlay/Android auto, check my thread: https://www.fullfatrr.com/forum/topic73930.html
With this setup, the rear screens, 4x4 info, cameras, timed climate, and valet mode all continue to work as normal.
Post #722960 16th Aug 2025 9:48pm
theJAFman
Thank you for the reply
Its actually 340 delived for 8 core now
But after some thought it seems the second method is the way to go but it still looks and feels rubbish
After all the research a perfect product does not exist yet or never will
So best is leave it just add bluetooth and use your phone on a cradle
But then i read u can do uad carplay with a oem screen upgrade?
Post #722962 17th Aug 2025 2:00am
exyjerome
https://www.fullfatrr.com/forum/topic73930.html - this is the same as the UAD kit, just a fraction of the cost. It keeps the original unit and adds Carplay/Android auto using the OEM screen.
The OEM unit with carplay is actually pretty good. I've been using it for over a month now and had 0 issues.
Post #722986 17th Aug 2025 12:07pm
theJAFman
May have to consider it
The alibaba link no longer works Crying or Very sad
Post #723015 17th Aug 2025 8:06pm
landy95
Try this one.
https://www.alibaba.com/x/1l9iuOh?ck=pdp Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
2012 Range Rover Westminster.
1991 Range Rover Vogue 3.9 V8.
Post #723016 17th Aug 2025 9:14pm
