Home > Maintenance & Mods (L322) > How Seized Engine Out L322 2011 4.4 TDV8 ?
D3Jon
RangerRover wrote:
It is out !
Brilliant effort, well done! Thumbs Up
That's what this forum is all about, doing it yourself! Bravo Thumbs Up Thumbs Up Thumbs Up
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #724193 8th Sep 2025 6:26pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hello from Düsseldorf to Munich, and respect for this achievement without a lift and only on the ground. I know all about it all. I would always buy, for example, a much cheaper L322 4.4TDV8 in the UK with a good but neglected engine for around 4000 GBP, drive it under its own steam via the Eurotunnel to Munich, rebuild the still-good engine 1:1, and sell the rest in parts. I've already done that; in the end, the engine was practically free. You can then disassemble the old, defective engine in peace and sell parts. Best regards, Uli, and also a big thank you to this always helpful forum full of gentlemen. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #725492 1st Oct 2025 8:13pm
RangerRover
Germany 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
After a longer period of not touching this project I go full steam into this now.
Engine is out, I plan to do the following:
Replacing Bearings
Replacing Piston Rings
Replacing Turbos
Replacing Injectors
Replacing High Pressure Pump
Replacing Seals where I see them weak old damaged
Replacing Water Pump
Anything I missed ?
Question: How do I determine the King Bearings size ? 0.25 vs 0.5 ?
Post #727056 28th Oct 2025 2:56pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Great effort so far 👏🏻👏🏻👏🏻
Have you stripped the engine?
Post #727077 28th Oct 2025 9:21pm
RangerRover
Is it possible to remove the piston bearings and main bearings without removing the timing chain ? My engine is perfectly in time and I rather like not touching the heads...
Post #727110 29th Oct 2025 1:29pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Not easily, possible maybe if you remove the tensioners and lift the crank a bit, but i wouldn't trust it to not jump a few teeth, then you're in a world of pain. I'd suggest whilst it's apart it would be sensible to replace chains, guides and tensioners anyway.
Timing it back up is easy enough with the correct tooling.
It's all in my thread "All I want for Christmas" from a few years ago.
Hope this helps L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #727111 29th Oct 2025 1:46pm
RangerRover
thanks mate ! You would change the chains ? My engine has 220.000 km
Post #727113 29th Oct 2025 1:56pm
4RRS
For the outlay, yes I would at that mileage! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #727116 29th Oct 2025 1:59pm
