Home > Technical (L405) > Rotary Gear Selector wont rise 'N' flashing
Ukandrewf
Hi all,
Couldn't find a thread dealing with this.
My Rotary Gear Selector won't rise and is flashing 'N' it won't go to park, and because it's still 'down', it won't allow me to select anything.
'Gearbox Not in Park'
Switches are on, power, engine runs fine, just no gears.
Any ideas? Any secret RR trick to reset the module?
AA attended but they could do nothing.
Andrew --
On my third Full Fat RR
Post #723228 21st Aug 2025 11:27pm
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Sounds like you need a new controller. Mine failed, would rise but I couldn't turn it out of neutral.
Pain to replace as need to remove the center tunnel to get to it. O think the new one was £690 2016 AB SDV8 Barolo black - Sadly sold
1995 RR Classic - Ex Police car - Now Sold
1994 RR 4.2 LSE - Long gone
Post #723229 21st Aug 2025 11:53pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
I'm sure there is a thread on this somewhere. There's an interlock that can be taped back to stop it engaging as a temporary fix. Sorry I can't be more specific but it's there somewhere.
Post #723243 22nd Aug 2025 9:02am
Ukandrewf
thanks for the tip will go an search --
Post #723252 22nd Aug 2025 10:20am
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
https://www.fullfatrr.com/forum/topic61043.html
Post #723258 22nd Aug 2025 11:44am
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
Mine went a few months back, it can be removed, sent away, repaired, tested and sent back, don't know how but they offer a lifetime warranty with it (probably 10 years in car terms).
Cost me under £400 with a specialist, go to Landrover and you'll get a four figure bill.
Have a look at my comments on it in previous thread.
Started looking on Ebay, but after a couple of backband forth comments, didn't get a good feeling, so walked away.
Post #723267 22nd Aug 2025 1:51pm
Ukandrewf
did you remove it yourself and send it away for repair?
looks like i could get a new unit for £300 ish then just need a garage to fit it.
also on my autobiography it had a rubber band type thing around the knob and this had started to flex a bit with age. I did wonder if that was the actual issue the rubber had bulged and perhaps cuased resistence as it wnet into the houseing stopping it reaching park. replacing the knob might fix it? probably more involved than that but I live in hope.
Andrew --
Post #723304 23rd Aug 2025 12:49pm
goldeneye32
Err No, garage removed it sent it away and then refitted it, I had to have the car recovered somewhere, and as I didn't know exactly what was wrong with it, it would've been stuck on my drive.
Post #723316 23rd Aug 2025 5:28pm
Crasher242
My unit failed too (there is a thread about it somewhere here). Although my failure was that it would not allow the drive selector to be rotated (it still would rise/fall ok).
But I think a lot of the sensing electronics are within the controller unit - so a sensor to tell when the ignition is on (to rise) and one for the brake pedal engaged (to allow the selector to rotate etc).
I removed it myself and sent it off to be repaired/renovated. Was about £450 or so for the repair, plus many hours of me cursing and swearing stripping it out and putting it back in again Smile
But it did save me a small fortune in garage bills. Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #723598 29th Aug 2025 1:40pm
Crasher242
Just a thought - have you managed to read any fault codes?
Have you checked the emergency brake release cable mechanism that is hidden under the cup-holder?
Its used to disengage the park brake - I seem to recall when I had to use mine (when the drive selector failed) that I got something similar warning on the dash?? Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Post #723599 29th Aug 2025 1:43pm
IIRC that red strap is to put the transmission in neutral if the gear selector fails, so you can move it onto a recovery truck, don't think it does much for the parking brake, you can put that in service mode with an IID or similar... Thumbs Up Pete
-Click here for Thread-
Post #723604 29th Aug 2025 2:16pm
fisha
The common failure of these seems to be the solenoid section not retracting back well enough. Whether it's the solenoid or the power circuit driving it.
There is a solenoid which retracts a locking pin back from the rotary dial. The locking pin is there to prevent the dial turning out of P, into D/R etc unless conditions are met ( like foot on the brake etc ). When it fails, then pin springs back into its lock position and the dial locks up in either direction, preventing you from selecting gears.
You can remove the rotary unit, open it up and use duct tape or similar to hold the pin in the unlock position all the time. The system then works as normal for the most part.
Mine failed, and in order to recover the car home, I did the duct tape method ... 6 months ago, and it's been running like that since without issue. I do have a refurbished unit waiting to go it, I've just not had the time/inclination to take the console apart again.
I may do that soon though as the car needs other things replaced, so it'll be inside and I'll do it then. I take pictures of the unit and the duct tape method. V8 or else ...
Post #723646 30th Aug 2025 10:14am
