![]() | Home > Maintenance & Mods (L405) > Just been Bodsy'd |
sullivj Member Since: 19 Jun 2025 Location: Gatwick Posts: 44 ![]() ![]() ![]() |
Could you give some more details of Bodsy please...? |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1851 ![]() ![]() ![]() |
Just search “Bodsy” using search facility above?
Will do - thanks. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Can be a bit difficult to get hold of. Texting might work best.
-L- Member Since: 05 Nov 2024 Location: Oxford Posts: 17 ![]() ![]() ![]() |
Updates by Bodsy - https://www.facebook.com/UpdatesByBodsy/?locale=en_GB
Think that was what I paid in March 2024. Top bloke and service.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Bodsy is a top guy and his work is legendary.
Took a little time to organise, but then he did come all the way up to Newcastle on Tyne to do ours to be fair, which I was very grateful for, he’s a busy guy. A proper gent, even sprayed a bit of Lanoguard on several rusty bolts for me while he was under there for a few cups of coffee. Thought the car was OK to drive beforehand, but it’s smooth as silk now, well worth doing bit of preventive maintenance. I tried to just let him get on with it as much as possible, I don’t like folks standing over me when I work. He did a great job, and not a drop split on my driveway, so my coffee must be THAT good! |
CerebralThunder Member Since: 16 Mar 2022 Location: Midlands Posts: 31 ![]() ![]() |
What is it he does exactly?
Gearbox, front differential, rear differential and transfer box oil change.
It’s something which really needs doing every 50K-60K miles to avoid future VERY expensive gearbox repairs or even a 5-figure replacement, -which is denied by JLR as being necessary, because they would love to charge you for a new auto box, Sir.
Thanks for the replies.
The “secret ingredient” is probably doing the job properly and with care. It takes a long time, waiting for the gearbox to come up to temperature at each stage before continuing, it’s not something you can rush or cut corners, it takes around 2 hours for just the transmission box alone.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1553 ![]() ![]() |
My understanding is that the gearbox learns under light acceleration where the revs are kept below 2000rpm, and also when you let it coast down through the gears.
