Home > Technical (L322) > Trailer light on?
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
Trailer light on?
Hi on my dash ( 05 facelift TD6 ) The trailer light is illuminated, when you touch the brakes or the indicators it goes off then comes back on once the brakes or indicators are cancelled, and when you turn the car off it sasy check trailer light?
Any ideas?
Thanks
Richard
Post #80519 12th Sep 2011 9:57am
have a look at the trailer socket under the the back , it could be damaged or water might be getting into the socket itself and causing a short ..
Post #80521 12th Sep 2011 10:03am
winslo
Come to think of it, after i washed it and took it out in teh rain the light was off......i will have a look later and spray some switch cleaner in them
thanks
Post #80522 12th Sep 2011 10:07am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Is the trailer light only on the face lift models?
I ask because my 2002 does not have one or if it does I have never seen it and my car spends most of its time towing.
Ian
Post #80786 13th Sep 2011 8:07am
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
I'm following this with interest, i tow a fair amount and have yet to see the trailer light on (TD6 MY06). I know i've had a trailer & horsebox with dodgy connections/bulb out and still nothing. Socket was replaced last year.
On my '95 Classic it was on all the time.
Post #80787 13th Sep 2011 8:22am
rayc
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
I have the same on my 07 model and my mate does on his 02.
I was told by Land Rover it comes on due to too much resistance in the form of dirty bulb earth or similar.
Mine I think is due to the caravan bulb holders being lightly corroded
Post #80871 13th Sep 2011 1:33pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
might be a bad earth. i get that sort of problem now and again hitching the wagon up to various trailers.hope this helps
Post #81308 14th Sep 2011 6:59pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Re: Trailer light on?
Any ideas?
Thanks
Richard
Hi, where is this trailer light? I've connected my caravan to mine and nothing on e dash tells me there is anything on the back. Everything works as it should - including the fog lights on the back of the car not coming on, but the caravan one coming on instead (as it should).
But nothing on the dash shows anything about a trailer - not even when the indicators are flashing...
Post #81392 15th Sep 2011 10:06am
i've just looked at the handbook and there is nothing suggesting that there is a trailer light....i can only assume its a warning light on the dash that lights up when towing...
it looks like the facelift models have this feature and not the older ranges... ... - .- -.
Post #81393 15th Sep 2011 10:18am
Simes
Cheers S.
I can't see any lig in the cluster on mine that looks like it would be a trailer light - you know how you can see them when the sun is shining in the right direction!
Post #81396 15th Sep 2011 10:37am
the facelift has a different dash hence the added warning light.. ... - .- -.
Post #81398 15th Sep 2011 10:41am
rayc
When I spoke to my delaer about mine I was told it only lights up when it detects a problem (ie resistance due to corrosion) and the check control for the car covers the trailer lights as well (Provided it's wired with the correct box of tricks I assume!).
Under normal circumstances the light doesn't show. Which differs from the old days when we used to have a "tell tale" on the dash.
My P38's flash with the indicators and check control does the lights.
My 07 has nothing but the check control and the trailer light showing when hooked up. (I can only assume as I said above it lights up when too much resistance is in the connectors for the bulbs due to corrosion etc)
Hope that helps Thumbs Up 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
99 Model 2.5 DSE Rioja Red / lightstone
97 BMW M3 Evo Convertible
plus a few more!
Post #81399 15th Sep 2011 10:41am
winslo
still on
Right, it's still on but ive been monitoring it and trying to find out why its on!
My lights are set to 'auto' so if its dark, the trailer light isnt iluminated, if the lights are off its on!!
If you press the brake ( kinda trail it ) the light goes off then comes on when you release the pedal!
If you have any indicator on for a longer period of time than normal the speed of the slash increases if there is a resistor fault or something..........
mmmmmmmmm any ideas???
Richard
Post #82122 18th Sep 2011 12:21am
