Home > Technical (L460) > dash cams !!! experience /advice
mkacala
United Kingdom 2019 Range Rover Autobiography TDV6 Carpathian Grey
hello all !
has anyone had a Blackvue dashcam fitted (I'm looking at the DR970 2CH latest one ).
I hear conflicting reports about battery drainage (with ALL dashcams in parking mode) however I'm told that will all dashcams (including the DR970) the suer can set the camera to turn off (in parking mode) if voltage drops below a minimum (say 12.4 volts) - obviously the minimum ca be set higher but then parking mode time will be limited since the L460 drops quite quickly after engine is turned off.
Just looking for any experience/advice from members .
Bytheway the 2ch DR970 costs about £570 plus £250 for fitting @ TTW/Blackvue main distributor in Notttingham.
Post #725692 6th Oct 2025 11:22am
jamesey
United Kingdom 2016 Range Rover Vogue SE TDV6 Corris Grey
I am also looking so would be interested in the answer... on my L405 the Nextbase i had drained the battery so i had to remove it when at home. Can you remove the Blackvue? Turning it off just puts it too sleep! But i now have the P550e hybrid so I assume as it has a huge battery that wont be a problem??? Or do they connect to a different battery?
Interested to know which Dashcams people went for and their experience. My Nextbase 622GW had great pictures for holiday snaps, but the app was so difficult to use i have to wait to get home to download the pictures i wanted to keep. And in the heat the camera would fall off the screen. & the battery drain. Hence seeing if there is now anything better!
Post #726234 15th Oct 2025 9:18pm
Phil.
In my experience of BlackVue dashcams on the L405, it drains the battery quickly. Yes you can set a voltage at which the dashcam turns off but this is soon after you have left in practice. You can buy a battery for a Blackview dashcam but it’s expensive.
I had the LR dashcam fitted in my L460 prior to delivery. The front/back cameras remain awake and record movements until the vehicle goes to sleep. I don’t know how they wired it in but it works. I wouldn’t go back to the hassle of a BlackVue dashcam. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #726260 16th Oct 2025 12:44pm
Gsxr1250dave
You can't beat a wolfbox
Post #726269 16th Oct 2025 5:29pm
Freddy Bear
I had the LR dash cam fitted to my L460 a month ago and am very happy with it.
As Phil noted although it is not fully integrated with the car (so you can’t view the images on the infotainment screen etc) it is intelligently connected electrically so you don’t worry about battery issues.
The install is pretty clean visually, too.
From my initial interest in it I now forget it is there mostly - but I do like the reassurance it is there if anything ever happens.
In summary I am glad I went with the LR product and would make the same choice again.
Post #726361 17th Oct 2025 10:35pm
JackRegan
Back in 2015, I had the BlackVue DR650GW installed in a L322 and was very happy with it. I think it cost £435 fitted.
I've been looking at getting one installed in my L460 so great to see what prices are now.
@Freddy Bear was your install after your car purchase, and how much did LR charge?
Cheers 2024 P550e Autobiography
2016MY TDV6 Autobiography
2011MY 5.0 SC Autobiography Black
2005 TD6 Vogue
Post #726367 18th Oct 2025 9:20am
Freddy Bear
Yes it was fitted a few months ago when the car was three years old.
I have decided to keep it for another three years at least so the investment is worthwhile.
Watched enough crash clips on Instagram to see the merit!
The LR website quotes £918 inc VAT for the parts and fitting. My dealer kindly gave me a 10% discount on that. From memory the split between the cost of the parts and labour was close to 50-50.
Given the need to integrate with the vehicle electronics and run a cable front to back I am very glad I had this done at a main dealer.
Post #726380 18th Oct 2025 12:13pm
JackRegan
Cheers @Freddy Bear 2024 P550e Autobiography
2005 TD6 Vogue
Post #726417 18th Oct 2025 11:19pm
diesel Dave
I have had the LR one for three years now, no voltage drop issues and was very handy when some bone head ran into me then his insurance tried to say it was my fault!
Looks neat and is very easy to fit in the L405.
Post #726427 19th Oct 2025 8:35am
