Home > Maintenance & Mods (L322) > Fire Extinguisher
Deep Down
France 2003 Range Rover Vogue Td6 Adriatic Blue
Fire Extinguisher
I'm about to fit a fire extinguisher just below the front passenger seat. Before I start drilling and screwing in self tappers, has any one here already fitted one? Any tips before I drill/screw through something I shouldn't.
Thanks
Post #84809 30th Sep 2011 7:33pm
On an 03 you should be able to cable tie the holder (not the extinguisher) to the bar across the base of the seat - at least that's what I did on my 04 when I had it - the newer seats aren't the same Crying or Very sad
Post #84811 30th Sep 2011 7:43pm
make sure you can still move the seat forward/back.. ... - .- -.
Post #84827 30th Sep 2011 9:06pm
Andy
Laughing 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #84967 2nd Oct 2011 10:05am
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
Bracket Drawings for Fire Extinguisher
I've just fitted an extinguisher to the factory mounts under the passenger seat.
10 minute job. Very Happy
Just 2 little brackets to match the holes in the bottom of the seat with the holes at the back of the extinguisher holder.
All details and measurements in this A4 page -
(Except for the mount holes thread size - anyone actually know what fits ? Rolling Eyes )
Post #343534 21st Aug 2015 4:18am
Zirconblue
You can fit the BMW X5 kit, it's about £75 for the extinguisher and the mounts (half the price of the LR one) The seat under frames are the same as the BMW X5.
There are already holes in the flat cross bar under there, they're not threaded you just force some 6mm bolts into them (cutting their own thread), that's the official BMW method!
You can also buy the BMW first aid box and mount under the other seat, about £25 from BMW. £50 with the contents. It's identical to the no longer available Land Rover one.
Post #343564 21st Aug 2015 10:18am
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
Hello, do you have pictures of the X5 parts installed? Thanks
Post #618971 6th Jan 2022 1:55pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Post #619360 9th Jan 2022 7:41pm
johnboyairey
ive used a small 1kg extinguisher, and you only get about 8 seconds, and its empty... so I chose a 2kg one, and fitted it on the rear parcel shelf side panel. I can climb over, from the drivers seat, just, if car is in park, and grab it quickly, or from rear opened door etc. its on a clip mount etc. it only cost £15 too. better to have plenty... than to run out! its very visible too, in case, im not in position to operate it etc.
Post #619362 9th Jan 2022 7:46pm
clemenz
darrenm wrote:
Thank you, but this is not from X5?
Post #619564 11th Jan 2022 2:12pm
Dean_C
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Has anyone tried fitting a fire stick type extinguisher?
I got one of theses in the other car, but I need it within easy reach of driver in there. Using specialist bracket for that. The fire stick arrived with its own plastic bracket.
You can get some that last 90 seconds, the one in picture is 30 seconds.
Post #619621 11th Jan 2022 9:05pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
That looks really nice & neat. Where can you purchase them from?.
Post #619645 11th Jan 2022 10:30pm
Dean_C
I got one form demon tweeks, search for fire stick, 30 seconds one was around £40 & arrived with its own plastic bracket too.
Post #619656 11th Jan 2022 11:48pm
