![]() | Home > Technical (L322) > Detachable Tow bar won't detach |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Now Im a fully paid up member of the caravanning fraternity, I've refitted my towbar. When I bought the car, it was fitted, but I couldn't remove the towbar, so I unbolted it from its square section housing and fitted the square blanking plug. I left the towbar to soak in WD-40 overnight.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
have you tried pulling the knob out when you turn it.. ... - .- -.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Turn the key, pull knob out, twist knob. |
Tried that- knob does pull out slightly, but towball still won't come out. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Big ball bearing has probably stuck, lube like what the man said. Fingers crossed. |
noddy , bang it with a hammer to loosen the 'ball catches' inside and turn and pull the knob while you are doing this.. ... - .- -.
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
I confused the FFRR forum with another I post on and now I've done myself an injury. |
