Home > Technical (L322) > TPMS
supershuttle
TPMS
If you buy wheels with TPMS valves, what do you need to do to make the car talk to them - anything? Geoff
Post #88085 19th Oct 2011 11:37pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
As a rule - the TPMS sensors should set up a connection with your car automatically (self programming) - I believe the system resets itself after you have started and driven the car a few times - if the wheels have been removed or swapped around the car for any reason - including the spare wheel.
I would have thought a car of your spec should have TPMS fitted as standard equipment - so if it is not working then it probably needs to be plugged into a reprogramming / diagnostic fault code reader gizmo to find out whats not working Neutral
Post #88088 20th Oct 2011 5:48am
However, its more than likely that they wont reconnect and it wont work.
I bought new wheels with new sensors and the TPMS module will not recognise them and I'll be damned if I am going to give the dealers £150 to stop a little orange light flashing.
I generally tend to notice if I have a puncture, I don't need a light to tell me its all gone wrong.
A piece of black insulation tape over the light obscures it nicely. Discovery 4 HSE
1998 90 TUL FFR Hard Top XD Wolf
1993 90 Tdi
*Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB
Post #88108 20th Oct 2011 9:35am
